1985 TPI vette 165 ECM swap....
Old Dec 8, 2007 | 07:06 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Ok, a friend of mine has a 1985 TPI 350/auto Corvette. The motor was rebuilt with the addition of a mild cam and 24 lb. injectors. So, I told him that I would tune it for him so it wouldn't run so rich (due to the bigger injectors, etc..) and I would use the 1989 vette .bin as a base that way it would start easier because he eliminated the cold start inejctor. I then realized that the stock 1226870 ECM does not have the same port as a 165 and newer ECM for me to plug a memcal adapter into. So, I grabbed a working 165 ECM and plugged it in. I used a 1989 F-body TPI 350/auto memcal/PROM and plugged that into the memcal adapter with the PROM that I programmed, then plugged that into the 165 ECM, then plugged that into the harness. I reconnected the battery and started it. It ran like crap with the check engine light on and it was in limp home mode.
My questions are:
Will using a F-body memcal even work?
If not, will using a 1989 vette memcal fix the problem?
Is there anything else I will have to change or swap so we can use the 165 ecm and '89 programming?
The .bin file I used was a slightly modified version of ARAP. Which has worked well for me in the past on an F-body.
Any thoughts?
Old Dec 9, 2007 | 11:05 AM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
Re: 1985 TPI vette 165 ECM swap....
Some info: http://www.eecis.udel.edu/~davis/z28/ecm_swap/
Old Dec 10, 2007 | 02:59 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Thank you for the info!
Still a couple of questions though...
Will the F-body memcal for a 1989 TPI 350 F-body work correctly hooked up to a Corvette or will I need to use a vette memcal?
If I need to use a vette memcal, what year memcal do I use?
Is there anything different I need to do to the vette that's different from the F-body 165 ecm conversion?
Old Dec 12, 2007 | 04:15 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Anyone??
Azrael91966669
25
Jun 20, 2017 04:04 AM
stalkier
Dec 6, 2015 11:25 PM
ezobens
Aug 19, 2015 10:29 PM
stalkier
Aug 13, 2015 12:59 PM
Sanjay
Aug 12, 2015 03:41 PM
