Mini Ram Intake???
Old May 27, 2001 | 05:45 AM
david auster's Avatar
Car: 1992 Camaro
Engine: 350 miniram
Mini Ram Intake???
Well I just purchased a mini ram from a friend of mine and I was wondering why TPIS didn't enlongate the middle intake holes to work on both kind of heads (pre 86 and 87-up). I have the Big Mouth Base, and it has provision's for both head setups, why doesn't the miniram have this? What head setup is the miniram for? I have a worked set of L98 aluminum heads I plan to use with it.
TIA
Old May 29, 2001 | 08:05 AM
91-ZZ4-Z28's Avatar
I dont know why they dont drill for both heads but they are for L98 heads. It is not that hard to re-drill them just use your big mouth holes as a template.
1991 Z28 ZZ4 with LPE superram base, SLP runners, LPE 58mm T-body,Random Technology ramair,TES headers,24#svo injectors,and just about every other bolt on that there is. Just got a ZEX nitrous kit!
Old May 29, 2001 | 03:54 PM
Guido's Avatar
Car: 2000 Trans Am
Dave, you may have gotten a hold of the Mini Ram 1. I dont think it had provisions for both types of heads.
I have a Mini Ram 2. I bought it new from TPIS and it is setup for both styles.
You will probably have to elongate the holes on your own. I know others have done it in the past so it isnt THAT big of a deal.
Good luck with it.
-86 IROC
Jacked up like a mother!
this years goal: 10.50 @ 130+ mph
-=ICON Motorsports=-
Old May 29, 2001 | 04:52 PM
ZBRA's Avatar
Car: 1972 Corvette
I have the Mini Ram II also, and it wasn't drilled for both style heads. I called TPIS, and they said some were and some weren't.
I redrilled the holes myself. It isn't the easiest thing to do. Just be patient. A drill that cost more than $15 might have made it easier on me.
If you have the Corvette aluminum L98 heads, then the intake will fit without redrilling the holes. If you have the F-body heads, then you will need to redrill it.
Good luck.
'94 Corvette Admiral Blue
-==ICON Motorsports==-
'91 Z28 Blue/Silver ZZ4/ZF6
335.9 rwhp 374.9 rwtorque
Bubbajones_ya
Jul 6, 2024 08:32 PM
Stangski09
Nov 14, 2015 01:27 PM
toronto formula
Sep 10, 2015 07:31 AM
64goatman
Sep 9, 2015 01:09 PM
09ave
Sep 7, 2015 06:03 PM
