advanced timing.. now it won't idle. why?
Old May 30, 2001 | 03:47 PM
MrJ's Avatar
MrJ
I had the timing set at 0 degrees (the car had been off the road since october, and the distributor had been out of the car) I ran it for about a week like this. Today I decided to advance it. I went through the normal procuedure, unplugged the EST spark connector, jumpered the ALDL, and advanced it to around 8 degrees. I go to start the car, and the idle quality is poor, and when I put it in gear it stalls out. What's the problem here? I had always had that advancing timing tends to smooth out an idle, not roughen it.
91 Trans Am WS6
Bright White
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
ported TPI setup
Built on Wednesday
Old May 30, 2001 | 07:45 PM
Guest
Guest
Posts: n/a
Since I didnt say it before, glad to hear you got the car running.
As for the problem, yea thats usually what happens. Is the distibutor in upside-down?
Make sure the plug wires are all hooked up in the right spots.
Old May 30, 2001 | 09:07 PM
Synergy's Avatar
Upside down ?!?
Make you knocked the IAC connector loose when you were fooling around with the distributor. Are you sure you plugged the EST connector back in ? If none of this helps go through the IAC reset procedure listed in tech articles on this site.
92 Z28 5.7
Trick Flow 23° heads, Comp Cams XR270HR-10 cam, Accel intake base + ported TPI,
TES headers, Flowmaster catback, MSD ignition, #24 SVO injectors, 1LE aluminum driveshaft.
Click here to see pics of my car !
Hotrodboba400
Dec 10, 2019 07:07 PM
Bohemian
Aug 15, 2017 05:11 PM
Jorlain
Oct 8, 2015 01:57 AM
Fronzizzle
Sep 8, 2015 12:10 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
