question on TPI Y-plenums
Old May 30, 2001 | 10:49 PM
james_fearn's Avatar
Why do some air intake Y-plenums have a threaded insert for a sensor? My 85 TPI doesn't have the threaded insert for a sensor but another I picked up at the junkyard did. I suppose it could be for an air intake temp sensor or something. Can someone shed some light into the application of this type.
1985 Z-28 305 TPI 223,000+ mi., Original Eng.,T-Tops,Blue/Grey
STB,SFC,GW "wonderbar",145 Speedo
Old May 30, 2001 | 11:33 PM
Guest
Guest
Posts: n/a
Its for the air intake temp sensor. Its probably the same deal as the Firebirds, the V6 cars (that I have seen) had them in a place other than the intake manifold.
Old May 31, 2001 | 04:33 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
supposed to be a good mod on v8 tpi cars to get the sensor to measure cooler air before it has the time to absorb the heat in the plenum
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
