engine question
Old May 30, 2001 | 10:16 PM
85monteSS's Avatar
engine question
ok, i have always been told that the third gen camaro had the option of a 5.7 liter L98, but the other day i was looking a a copy of CHP and it said the L98 was never offered in the camaro, only a L89 which was the same thing only it came with cast iron heads instead of aluminum. which is right?? thanks
1985 monte carlo ss, vortec heads, edelbrock headers, intake, open air element, k&n, 1.6 roller rockers
Old May 30, 2001 | 10:39 PM
Scott 88 GTA's Avatar
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
The LB9 is the 305 TPI engine. The 350 TPI that came in Thirdgens is an L98 with iron heads as the magazine said. However, sometimes the engine code for a Thirdgen is called B2L, but this was usually a package that included the L98 I believe.
Black 88 GTA L98
261 RWHP, 345 RWTQ
13.406 @ 103.72 MPH
ZZ4 bottom end, Edelbrock 6085 heads, LT4 HOT cam, GMPP 1.6 RR's, ported stock TPI, SLP 1 3/4" headers, no cat, Dynomax cat-back, Stock PROM
E.T.F.A Member #11
Old May 30, 2001 | 10:52 PM
mjdoyle's Avatar
my 88 iroc has a factory L98 in it. So yes they did come with L98's
Old Jun 2, 2001 | 10:28 AM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
l98 is aan option code or rpo code(regular production order)the l98 is an rpo code but is different in thaat all l98's had 4 bolt mains and aluminum heads so when you ordered a camaro or firebird inthe 85-92 era the option for the engine only lists codes lb9w/auto or manual tranny and in 1987 the b2lw/ auto tranny only so l98's never came in a 3rd gen just a 350 modeled after the l98
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
