HELP were isRadiator fan relay??85'Z28
Old Jun 1, 2001 | 09:45 PM
MrMike99's Avatar
on a single fan 305tpi Z28, were is that relay located? I need to check it my friend car is overheating. thank mike
Old Jun 2, 2001 | 01:36 AM
james_fearn's Avatar
It by on the passengers side of the car by the radiator. It should be the only relay by the radiator side support and by the battery. There should be a wire that comes off your batterys (+) side that goes to that area. You can't miss it.
James
1985 Z-28 305 TPI 223,000+ mi., Original Eng.,T-Tops,Blue/Grey
STB,SFC,GW "wonderbar",145 Speedo
Old Jun 2, 2001 | 12:52 PM
irocrob's Avatar
Car: 1985 Chevrolet Camaro IROC
That is exactly where it is locatedas mentioned above. I currenty own an 85 IROC with a single fan setup.
Rob Kowalski
85 IROC, 305 TPI, JET AFPR - 45 PSI, B&M Megashifter, B&M Shift Kit, 3.42 gears, SLP Airfoil, SLP 1 5/8 headers and cat back system, gutted cat, gutted airbox, MAF screens removed, K&N, more to come!!
my86bird
Oct 23, 2015 12:20 PM
64goatman
Sep 9, 2015 01:09 PM
Gunsbee
Sep 7, 2015 07:10 PM
85Special
Sep 3, 2015 04:21 PM
