Tearing off the top half of my motor.. tips?
Old Jun 2, 2001 | 02:44 AM
Roshambo's Avatar
Well, my heads (L98) should be here monday, or tuesday. So, Im going to tear the Plenum, runner, and intake off tomarrow. All my work was always done on carbed motors, so this is my first attempt at TPI!
So, is there any tips anyone has? I wont be doing this alone, but, I dont want to screw anything up on accident, just because I didnt know!
Im planning on porting and polishing my plenum and runners, and tackling siamesing the intake as well.
Well, its late, and Im getting tired! Any help would be greatly appreciated!
-Roshambo
Old Jun 2, 2001 | 03:08 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I just did what your are about to do.
I took of my carb, intake, and heads.
I put on the 87 TPI heads, and waiting on a few parts to arrive so that I can start to put the TPI on.
The only tip I can think of now is to make sure you organize all of your bolts, since you will have a whole bunch lying around.
When you put your head bolts on, clean them off and use thread compound on the end of the bolts to keep water in the block from seeping out around the bolts. I don't remember what the compound is called, I didn't use any, but I don't plan on keeping my 305 block for long. I am just trying to make the TPI setup work, then I'll be searching for a 350 block to assemble and drop into my car.
High Speed Run: 157mph
Best 1/4 mile run: 14.94@91.67mph
WS6 Trans Am.
View My Ride @ thirdgen.org
Old Jun 2, 2001 | 08:00 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Use some masking tape and a marker and label all of the connections. Use Teflon sealer on the head bolts in the water jackets and on the intake bolts.
Make sure you clean all of the shavings out of the heads real good, sometimes machine shops don't do a good job.
Ghettobird52
Apr 21, 2020 08:44 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
NiG
Sep 2, 2015 06:54 AM
