Replacing Fuel Injectors
Old Jun 3, 2001 | 04:20 PM
Panthro's Avatar
Car: '89 Formula, Black w/ gray interior
Engine: LB9, 230 HP, 305 ci, TPI
Transmission: 5 sp manual
Axle/Gears: Borg Warner 3.45 limited slip
Hey Folks, It's been a while. My #2 fuel injector has died (>10 ohms) and killed my whole fuel delivery system. I've got 2 questions: first, can I replace it without removing the upper plenum, and if it's possible, is it worth it to try? Second, if one has died, should I expect the others to follow soon? It's an '89 w/ 92,000 miles. Thanks for the input.
Pat McGrath '89 Formula LB9, T-5
Old Jun 3, 2001 | 05:29 PM
rondubbs's Avatar
you have to take off the plenum to get the injector rail out to get to the injectors.. while they are out you might as well send them to get tested and flowmatched by rich @ http://www.cruzinperformance.com/fuelinj.html
this is the only place to send with your injectors. ask around everyone will agree.
good luck
Old Jun 3, 2001 | 10:32 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
yeah you'll need to remove the plenum and runners to get to the fuel rail.well i would say if you can afford it replace all of them.what if another one craps out on you in a couple months?you'll have to do it all over again!
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://discussion-board.com/GreaterC...dyAssociation/
http://www.cincyspeed.com/
92camaroJoe
Jul 29, 2023 07:57 PM
specialized
Jun 18, 2022 09:26 AM
Brcharrelson
Aug 26, 2015 07:47 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Firechicken86
Aug 12, 2015 10:07 PM
