What cam do you have - why did you choose it?
Old May 31, 2001 | 01:15 AM
PerthZ28's Avatar
What do you have, why did you choose it, what's it in, what is it like [idle, torque, power, fuel etc etc]?
Old Jun 2, 2001 | 05:44 AM
PerthZ28's Avatar
Anyone??
Old Jun 2, 2001 | 09:43 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
You choose a cam based on your mods and your power level. There are better ways to get power other than swapping cams if you have a stock motor.
One of the best ways is to use a program like dyno 2000 or engine analyzer, that lets you run different engine combinations and see the effects of your changes. Not 100% accurate, but close enough.
Old Jun 4, 2001 | 12:37 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Price had a lot to do with my choice. I had my eye on the largest of the SLP cams (p/n 51010 I think - adv duration 280*,288* @.050" 224*,230* 502"I, 510"E) but the LT4 Hot Cam is VERY close to the same specs (adv duration 279*,287* @.050" 218*,228* 525"I, 525"E) as the SLP one and I still get my discount through the dealership I used to work at so the GMPP cam was about half the price of the SLP one for me.
I originally had looked at the SLP cam after a few recommendations from people who are running it and after looking at their setups/times. I knew I was putting in a stall converter so losing a little low end was not an issue and I figured my other upgrades/mods would help the cam work on the high end. You just gotta remember that everything works together - heads, cam, intake, exhaust, etc... - and if any ONE thing does not match, you will not see the power that you might expect/want. I haven't run mine hard yet as it only has 160 miles on it, but it sounds and feels very good.
1987 GTA L98 MD8 GH3
355 '97 Vortec 4-bolt block, TRW(suck) forged pistons 10:1 CR, TFS 23*, LT4 Hot Cam, Ported plenum and intake, SLP Siam Runners, Edelbrock TES, gutted Cat, Flowmaster, Home-made cold air system w/ K+N cone and AFPR, TB bypass, AirFoil, !AIR, !A/C, !EVAP, 2300 stall.
"Stop Lights timed for 35Mph are also timed for 140Mph"
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
masonta
Sep 1, 2015 06:40 PM
