Code 32, V6 Only?
Old Jun 3, 2001 | 09:22 PM
85 T/A WS6's Avatar
Car: Recaro Option T/A
Engine: 305 Tuned Port Injection
Transmission: Automatic
Axle/Gears: 3:27 Borg Warner
Code 32, V6 Only?
I had a cascade crew buddy plug in his scanner and while doing the Vulcan mind thingy a code 32 was detected. His Hayes repair manual id's this as an EGR problem for the V6, but being a 305 jockey I am stumped and mystified. Any insight or enlightenment would be welcomed.
Don
1985 T/A WS6
Recaro Seats
57,000 smiles
TPI T-Tops
3:27 Posi
K&N
Old Jun 3, 2001 | 09:54 PM
Vader's Avatar
Don,
The '32' is a fairly universal (among GM PCMs) DTC. Maybe this would help:
GM ECM Error Codes.pdf
You'll need Adobe Acrobat Reader to view/print the file (see below).
Later,
Vader
"Let the bodies hit the floor!"
Old Jun 3, 2001 | 10:27 PM
85 T/A WS6's Avatar
Thanks Vader, your legendary!
The fact that an accomplished F Body author lists thirdgen.org as the first link for 3rd Generation Firebirds / Trans Ams proves that this board rules !
Now the big question, is it a MAP circuit issue or an EGR curcuit fault, only time will tell
Don
Old Jun 3, 2001 | 10:46 PM
Vader's Avatar
85,
Is your TA a TPI or carbed engine? Apparently the TPI/EFI only uses the '32' to identify an EGR problem. The carbed engine can use a '32' or '53' for an EGR diagnostic fault.
One unusual thing I encountered with a MAP error was a faulty PCV valve. The valve wasn't really faulty, but apparently Fram either packaged the wrong PCV, or the quality control was so bad that the flow rate of the PCV was completely wrong for the engine. A new AC/Delco PCV valve solved the problem, and the brand new Fram PCV valve was summarily "dismissed" in a nearby bench vise.
You should also check other less common vacuum leaks, like the brake booster (pinch the line) and EGR valve itself (block-off plate).
There are several ways to help diagnose the EGR problem, but the two fuel systems are different enough to have different procedures.
Later,
Vader
Old Jun 3, 2001 | 11:53 PM
85 T/A WS6's Avatar
TPI, dont settle for anything less :-)
Don
1985 T/A WS6
Recaro Seats
57,000 smiles
TPI T-Tops
3:27 Posi
K&N
Old Jun 4, 2001 | 12:03 PM
Crusader's Avatar
Car: 1988 Firebird Formula
Axle/Gears: 3.45
<font face="Verdana, Arial" size="2">Originally posted by 85 T/A WS6:
</font>
Ditto that.
1988 GTA - 5.0 Auto
1989 Firebird - 2.8 5-speed For sale!
My Page - http://transam.freeservers.com
Firebird owners check out http://transamgta.com
"But as our comparison-test results prove, when it comes to the Mustang and its loyal fans, we just don't get it." - Car & Driver
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
