checking fuel injectors
Old Jun 3, 2001 | 10:41 PM
cobrakiller1989's Avatar
I want to make sure all of my fuel injectors are firing properly. I would like to send them off and have them cleaned and flow matched but i cant afford to have my car off the road for about a week. Does anyone know a way to check to see if they are working properly. thanks
*1989 RS
*Red, Daytona Turbo fiberglass hood, chrome 16x8 IROC wheels
*355 CID
*TPI ported plenum, SLp siamesed runners, Edelbrock high flow intake
*Edelbrock TES Headers (getting SLP 1 3/4 this summer)
*Richmond 3.73
Modded 700-R4, 2800 stall converter
NO recent time slips.
Old Jun 4, 2001 | 11:37 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
The only thing you can check with the injectors in the car, is if they are flowing fuel at the same rate.
You'll need a fuel pressure gauge and an injector testor/cycler. ONly problem is that you won't be able to tell if the spray pattern is good or not.
May want top try rich at Cruzin Performance, he has great turn around time, and you may be ableto work a deal with him to minimize downtime.
Old Jun 4, 2001 | 12:11 PM
P J Moran's Avatar
Car: Used to be an '87 IROC
Engine: 5.7l TPI
Axle/Gears: 3:23?
A reliable mechanic "friend" of mine recently told me to use a mechanic's stethescope. You can get one for $10 at AutoZone. Listen to each injector. It should make a nice, crisp, ting-ting-ting sound like metal to metal. Dirty or fouled ones won't make as crisp a sound. Non- functional ones are quiet
This test won't check flow balance, of course. Chances are, if they are clean and working, the flow is reasonably well balanced.
'87 IROC 5.7l TPI - original owner!
pimp2303
Jul 27, 2017 02:03 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Brcharrelson
Aug 26, 2015 07:47 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
