LT1 cams in L98??
Old Jun 3, 2001 | 08:59 PM
WHITE87GTA's Avatar
LT1 cams in L98??
can a cam that is ground for a LT1 work in a L98? if not is there some way for it to work?
Old Jun 3, 2001 | 09:57 PM
Vader's Avatar
Go to the Tech/General Engine board and ask New87. He's got an LT1 cam in his 305 and dropped a good chunk from his times. The cam fits just fine, distributor drive and all. Just remember to adjust the drive dowel to the correct depth for the older engine. Usually you can just tap the dowel farther into the recess to fit the old cam sprocket and still clear the timing cover.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Jun 3, 2001 | 10:18 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
On some of the LT1 cams the dowel sticks out about .600"and all you have to do is tap it back into the cam so that it is sticking out about .300"like the L98 cam.If you can't tap it in far enough,then you can grind it down till you reach the .300".
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://discussion-board.com/GreaterC...dyAssociation/
http://www.cincyspeed.com/
Old Jun 3, 2001 | 11:16 PM
90 Z28SS's Avatar
but yeah , other than the lenght of the dowl , its a direct swap
Old Jun 3, 2001 | 11:22 PM
WHITE87GTA's Avatar
thanks for the responses
Old Jun 4, 2001 | 10:42 AM
Beefy89's Avatar
I'm running an LT1 cam in my L98 with 1.6 roller tips.Like the other guys said,it's a direct swap except for the dowel pin being .300" too long.
Fast as a shark~~~~~~~~~~~~~~~~~ SAVE NAPSTER!!!
Old Jun 4, 2001 | 12:41 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
Like Vader said I did the swap in my LB9. Now I run 14.6 @ 93 mph. Before the swap I was running 15.4 @ 87mph as a best and 15.5's all day. I'd have to say though I did the swap becuase I got the cam free and any thing is better than the peanut cam. Your 350 cam is just a little smaller LT1 so if your going to do all that work to swap put a good after market cam in.
87 Z28 305 TPI, Auto, LT-1 cam (@.50 418/430, 194/199, LSA 111), roller timing set, 2.73, Gutted air boxes, K & N fillters, Dyno Max 3" cat back, 8.8 mm spirals, air foil, BFG Drag radials, and 170* Stat.
Old Best 15.414 @ 87.47.
new best 15.006 @ 89.55.
w/ drag radails 14.6 @ 93
“Fallen But Not Forgotten”
Old Jun 4, 2001 | 09:15 PM
Dan87IROC-Z's Avatar
The dowel sticking out isn't a problem, my LT4 HOT Cam was that way and I just tapped it back in like 10 seconds. I don't know if you would gain a whole lot by putting an LT1 Cam in an L98, there probably isn't much of a difference. The LT1 Cam is a better mod for an LB9 or LO3.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Catco High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Soon to Come: 7.625" 10 Bolt with 3.42s and Accel TPI Intake Base
Old Jun 4, 2001 | 11:31 PM
91banditt2's Avatar
Engine: 5.7 HSR
<----is going to use the LT1 cam with 1.6 RR's
Old Jun 5, 2001 | 02:34 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Just as a point of reference, I used an LT1 cam (201/207 duration) and ported stock iron heads, ported stock TPI intake, SLP 1 5/8" headers, and 1.65 roller rockers, and it made 250 HP and 335 TQ at the rear wheels.
There are 3 or 4 versions of the LT1 cam, depending on which year you get. You can check http://www.f-body.org/tech/ in the 4th gen section for the specs.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
lt500r55
Sep 1, 2021 01:30 PM
midge54
Dec 27, 2019 04:14 PM
italiano67
Aug 31, 2015 06:04 PM
midge54
Aug 29, 2015 09:51 PM
TheExaminer
Aug 19, 2015 10:07 PM
