TPI Engine Pic
Old Jun 6, 2001 | 10:49 PM
Jas89TTA's Avatar
TPI Engine Pic
Well, I finally got some pics of my engine and thought I'd share them. I think it turned out great. Daniel Burk did the powder coating and porting work on the system.
Here is the link ( I hope it works)
http://albums.photopoint.com/j/ViewP...p=49965925&f=0
[This message has been edited by Jas87T/A (edited June 06, 2001).]
Old Jun 6, 2001 | 11:00 PM
RARE-ROC-Z's Avatar
man there is alot of red under there for having a burgandy/black car. whichever color it is.
its looking good, i would have painted all the mounts black but thats not my engine, so its all you man.
and i like the powdercoat idea!
great job.
Jarrad
1990 IROC-Z L98 350 TPI
TH-700R4
G92- 9 Bolt Borg-Warner 3.27gears
Bright Red Hardtop/ Grey "Custom" Interior
NOT STOCK, NO WHERE CLOSE!
NEW RED PAINT and WELD PROSTARS.
DAILY DRIVER: 1991 GREY S10 2.5L/5SPD -FOR SALE. leaving for army.
Old Jun 6, 2001 | 11:02 PM
cobrakiller1989's Avatar
the pics wont show up for me, can u post the links
Old Jun 6, 2001 | 11:30 PM
Jas89TTA's Avatar
Ok, I added the link as I could not get the pictures to show up I kept getting a red x instead of the picture.
Old Jun 6, 2001 | 11:56 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
That looks pretty good. Just get some of that stuff out of the engine bay and you will have a really nice setup.
A couple hints from a guy that has an '87 v-belt system as well:
If you can, cut off the AIR pipes from the headers and have the holes welded shut. It is amazing how easily it is to get to your plugs after that and how much it cleans up the engine bay.
You can get almost all of the A/C brackets off of the driver side head and retain the power steering pump bracketing system.
Is that a smog pump I see in there? That, and all of its brackets have to go.
You can bypass the TB coolant and re-route the heater hose from the intake to the heater control valve and move the valve itself to the passenger rear of the engine bay.
After all of that stuff is removed, along with what you have already removed, you will be shaving a good 100 lbs off the front of the car (The A/C compressor and the smog pump are freakin heavy aren't they!!!! ..... than add all the brackets, bolts, belts, A/C condensor.....etc.)
Keep up the good werk.....
1987 GTA L98 MD8 GH3
355 '97 Vortec 4-bolt block, TRW(suck) forged pistons 10:1 CR, TFS 23*, LT4 Hot Cam, Ported plenum and intake, SLP Siam Runners, Edelbrock TES, gutted Cat, Flowmaster, Home-made cold air system w/ K+N cone and AFPR, TB bypass, AirFoil, !AIR, !A/C, !EVAP, 2300 stall.
"Stop Lights timed for 35Mph are also timed for 140Mph"
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Sep 3, 2015 10:56 PM
R3500
Aug 17, 2015 12:16 PM
Sanjay
Aug 12, 2015 03:41 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
