91 Z28 Cam, Head, Computer Combo Questions?
Old Jun 7, 2001 | 02:50 PM
Doogie92Z28's Avatar
I have a 91 Z28. I am looking to run a new set of heads, cam and a custom burned computer. What is the best combo. I am wanting major horsepower and great sound. Thanks for your help.
Old Jun 7, 2001 | 03:14 PM
mirage2991's Avatar
need more info on what mods you already have, if you need to pass inspection, what kind of driving (daily or race)....but I had friends that had good results with high lift cam/low duration on there blue ovals speed density. I've heard and red that AFR heads are the ticket for great HP...I think a rule of thumbs for cams in a daily driver aplication would be the highest lift you can get by and a small duration (some like the ZZ4 cam with 1.6 rockers...208 dur and 530 lift (?) ) And if you are going to run LTR, shoot for a power band between 1500 and 5000 rpm, for the LTR are not ment to rev much above 5k (unless highly modified). Matching your items will give you a much better result than just geting a high rev cam hooked to low rev intake (TPI) on a set of cavernous heads...
Old Jun 7, 2001 | 04:18 PM
AlexJH's Avatar
Engine: 5.7L V8
Doogie,
I'm looking at doing a buildup as well, and this board seems to agree that the AFR 190's are the best head (but they cost $1250), followed by the Trick Flow 23* heads ($829 at Summit).
Old Jun 7, 2001 | 04:37 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
trick flow 23 degree heads accel 211,219 camshaft,edelbrock base(cheaper than accel)super ram plenum with fully siamesed accel runners heads may have to be milled to keep your compression up!that'll give you a large plenum short runner design intake(6 3/4 in. or so,but not nearly as short as the lt1's 3in. runners)to match the flow of the heads and the "rpm operating range of the cam"
87 trans am 350 L98 aluminum heads,LT4 hot cam,slp runners,headers,y-pipe,edelbrock base,hi flo cat,air foil,ported plenum,t-5 tranny w/centerforce clutch and a 3.27 9bolt,ads strip chip,relocated iat sensor,hollowed maf
14.10@97mph w/2.01 60' 4SALE anyone want her?
Old Jun 7, 2001 | 06:59 PM
Mirage,
Right now i have a full 3 inch flowmaster exhaust, high flow cat, bosch plugs +4, MSD wires, hypertech chip, slp headers and y-pipe, throttle-body-bypass, comp ail foil, 160 degree thermo, and k&n filterchargers. Hope this helps.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
anesthes
Aug 8, 2015 09:37 PM
