water in exhaust?
Old Jun 6, 2001 | 04:34 PM
danzig27's Avatar
Car: 91 Camaro Z28
Transmission: TKO 600
Axle/Gears: 10 bolt 3.23
water in exhaust?
Whenever I start my car, I get water to drip out of the exhaust. I wouldn't be asking this considering that for the most part I thought it was normal, but I've got more than most cars. But it goes away after a little while. I also get a little bit of white smoke at startup, could that be just the exhaust heating the water up that's left inside the pipe? Thanks for any help!
Wally
Old Jun 6, 2001 | 05:02 PM
Mo's Avatar
Mo
I'd say its normal, especially on cold mornings, i can see it on the ground for about a foot after the tail pipe, but it stops after a couple of minutes.
90 IROC 5.7l (L98)
ram air, K&N's, air foil,Flows
LIKE A ROC
http://members.nbci.com/IrocZgarage/home.htm
Old Jun 6, 2001 | 10:25 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
the water coming out of the tail pipe is normale
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://discussion-board.com/GreaterC...dyAssociation/
http://www.cincyspeed.com/
Old Jun 6, 2001 | 11:03 PM
danzig27's Avatar
Car: 91 Camaro Z28
What about the white smoke?
Wally
Old Jun 7, 2001 | 12:45 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
If you have a friend start the engine and get to the back of the car and smell the (White smoke) it could be only steam, or it could be your valves are leaking, and you get some oil in the intake, when you start the car it is burned off.
If it smells like burned oil, then you more than likely need to have a valve job done.
87 Formula 5.1 converted to TPI Yellow/Black
SLP cam, headers, cat-back exhaust
Ported & polished TPI intake
Gil Younger (no yo-yo) Shift Kit
Aluminum Driveshaft
3.73 Posi gear
Baer 12" brakes 4 wheels
Hotchiss strut tower brace
South side machine frame connecters
Custom reinforced control arms and pan hard bar.
Custom Leather interior
87 Formula TPI (5 Speed) Yellow/Gray STOCK
83 Camaro (Parts)
83 T/A (parts)
www.3rdgenformula.com
Old Jun 7, 2001 | 01:03 PM
CamaroX84's Avatar
In any combustion reaction, the reaction is:
Hydrocarbon + Oxygen Gas produces Water + Carbon dioxide gas
If our vehicles were 100% efficient, we would spit out pure water and carbon dioxide out of the tailpipes. But, because complete combustion is almost impossible, we get left over hydrocarbons and carbon monoxide. So, like the other guys said, the water is normal. Just thought you guys might want a little chemistry lesson. :-)
Old Jun 7, 2001 | 01:43 PM
88IROCs's Avatar
Actually the chemistry is a bit shaky. Humans and all living things exhale carbon dioxide(2 oxygen molecules). Trees and plants recombine this to form O2(the stuff you need to keep breathing).
IC engines create carbon monoxide, which is harmful to all living things. Btw, sniffing directly from the tailpipe may not be the smartest thing, as the effects of inhaling CO are cumulative and will lead to brain damage(sniff a little CO and you'll start shooting admiring glances at Ford's, sniff too much and you'll end up driving one).
Old Jun 7, 2001 | 03:53 PM
Mo's Avatar
Mo
ha 88 very funny
Old Jun 7, 2001 | 11:11 PM
CamaroX84's Avatar
Lol, all I was saying is that in COMPLETE combustion, no carbon monoxide is produced, but COMPLETE combustion is virtually impossible with our motors.
Hotrodboba400
Dec 10, 2019 07:07 PM
92firebirdguy
Sep 1, 2016 07:53 AM
customblackbird
Oct 1, 2015 04:30 PM
Djmathis123
Sep 8, 2015 08:42 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
