When removing smog stuff, what can be removed without engine codes showing up?
Old Jun 5, 2001 | 08:19 AM
86Tra/maro's Avatar
From: Newark,NJ The state where racing on I 78 rules.
I have a 86 305 TPI. My question is can the smog pump & all those crappy hoses , EGR valve (my egr has a wire coming out of it?) be removed without triggering a check engine light code? I just bought a new 383 roller engine that Im about to install & just hate all of that crap in the way of my valve covers & headers. Last question is, will my 305 injectors be enough to start the car with the new engine?
86 Tramaro 90% Trans Am/ 10% IROC/Z (nose, hood,& fenders)
Trans Am Mods as of 1/10/01
3inch
T.E.S/Flowmaster setup,gutted cat,gutted maf,relocated mat,373 gears,upgraded factory chip,255 liter h/press. walpro f/pump & throttle body coolant bypass
njdaewoo@excite.com
Old Jun 5, 2001 | 12:43 PM
whiterocz's Avatar
i removed it all, pump, hoses, metal lines, all of it, and just unplugged the connectors on the bottom of the box and it didnt throw a single code. i removed it because i put on headers and they didnt have the a.i.r. tubes so i just took it all off. problem free for over 6 months.
Old Jun 5, 2001 | 12:45 PM
whiterocz's Avatar
btw, you got any pictures of your car? id like to see that.
Old Jun 5, 2001 | 02:57 PM
mirage2991's Avatar
same here, on my 85 350, hypergarbage chip, no EGR, trouble free for the last 5 years, never a code....
Old Jun 5, 2001 | 11:40 PM
86Tra/maro's Avatar
what did u use to block off the EGR hole? Did your EGR have the wire comming out of it? I heard that wire measures the heat from the exhaust gas & if it dosn't sense any heat it will set off a engine code.
Old Jun 6, 2001 | 12:18 AM
Guest
Guest
Posts: n/a
<font face="Verdana, Arial" size="2">Originally posted by 86Tra/maro:
I heard that wire measures the heat from the exhaust gas & if it dosn't sense any heat it will set off a engine code.</font>
Disconnect it and find out. Theres a single wire disconnect for that sensor near the distributor.
Ive never had a MAF car set a code for the EGR yet... though I have heard of it happening to people.
Old Jun 6, 2001 | 03:00 AM
Omar's Avatar
I have removed ALL of my emmissions equipment at one point in time and never set a code.
1989 IROC-Z 5.7L
NOS 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old Jun 6, 2001 | 01:01 PM
86Tra/maro's Avatar
Motors going in today. Ill let u know if the code sets. What about the 305 injectors will they allow the engine to crank up & run? I dont have an adjustable fuel pressure regulator yet.
Old Jun 7, 2001 | 08:36 AM
irocbsa's Avatar
The injectors should fire the car and allow it to run. Running effeciently and properly is another story.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Edelbrock Intake, Accel Runners, Comp Cam, Crane Gold rockers, Lucas 24# injectors, Edelbrock headers, Flowmaster 3'' exhaust, Mallory Ignition, Transgo Performance Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
Old Jun 7, 2001 | 10:17 AM
Desert86Roc's Avatar
Disconnecting your EGR will cause a code to be set under certain driving conditions...usually when you are cruizing at a steady speed on the freeway. You will get a code 32 - EGR Failure. After you turn the car off for a few minutes, it will go away until the next time.
Also, if you have to go thru emmissions, you will have higher NOX readings without the EGR...so much more, that you may not pass.
Mike Metzler (Desert86Roc)[*] Check Out:SpeedWorldMotorplex.com[*] Check Out:Chevrolet F-Body Online Part & Illustration Manual[*] My 86 IROC 305 TPI Page (406 build in progress)
ET's @ 1250 ft[*] 14.28 @ 95.461 mph (uncorrected, NOS, no headers)[*] 15.362 @ 88.238 mph (uncorrected, headers, no NOS)
&lt;&gt;&lt;
Old Jun 7, 2001 | 02:34 PM
Fred91TA's Avatar
Car: 1991 Trans Am
Transmission: 4L60
Can the EGR be functional without the smog stuff? I'm about to rip the smog stuff off my car and just use the dual cats, but I'll leave the EGR if it will still work and serves a purpose.
91 TA 5.7 TPI Automatic.
w/WS6 and 3.23 rear.
K&N Air Filter,Hypertech Coil,Moroso Blue Max Wires, Bosch Platinum plugs gapped at .050,
JET fan switch,JET air foil,Dual cats with Flowmaster 3" exhaust (Headers coming soon),
Complete PST components on front suspension, Spohn LCAs/Panhard bar.
It's not much, but it's a start and I have a Summit catalog! :-)
Old Jun 7, 2001 | 11:12 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Fred, yes you can take all the a.i.r. stuff off and the EGR will work fine without it. They are completely separate.
86tra/maro, you ought to consider bumping the fuel pressure up without an adjustable regulator. I think there's a tech article in the FAQ on how to do it. Something like putting a penny or nickel in the regulator to stiffen up the spring. As for the EGR, I'd leave it in place if I were you. Otherwise you'll throw a code on the highway from time to time, as someone already mentioned. Of course with a stock prom you're bound to throw a code for it anyway. I also have all my a.i.r. stuff removed and have headers without the lines (cut them off) so if you want to see a pic you can check it out at my web site.
91 Z28
Come see The Vicious...
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
3rdgenparts
Aug 8, 2015 07:09 PM
mustangman65_79
Aug 7, 2015 09:55 PM
