Accel/Lingenfelter Super Ram?
Old Jun 6, 2001 | 08:55 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I'm planning on buying a new intake system. This is what I got--Crate ZZ4, Accel 30# inj., Holley adj. fuel pres. reg., MSD 8.5mm Super cond. wires, Cranes Cam HI-6S ign. w/ PS91 coil, K&N filter, Jet Air foil, Hooker Comp. 1 5/8" shorties, american thunder flows, oil cooler, Dual friction centerforce.
I want to buy a BBK 58mm TB.($310), the super ram base($460), Super ram plenum and runners($760). NOW MY QUESTION--- Will the intake base fit on the the heads w/ no prob.?
When I tried to put the stock TPI setup on the engine the bolt holes did not match up. I had to oblong the holes in my stok TPI to get it to fit. I would like to avoid that with the new one. Please help me, I've posted this at 4 other tech sites and no one knows for sure. Thanks.
Old Jun 6, 2001 | 09:29 PM
LeeH's Avatar
Car: 89 Firebird Formula
Engine: 389
Axle/Gears: Moser 4.11
That's pretty much the6 same setup I have, except I went with 24# injectors. They are good for at least 400 HP, and the ZZ4 only puts out 355, so you will be running it pretty rich unless you back way off on the fuel pressure and burn a custom prom to set the pulse width and stuff back a bit.
The Superram has a dual bolt pattern for the center bolts, so it will fit both the new and old style heads.
http://www.havemann.com/lee/firebird.html
1989 Firebird Formula, WS6 Package
ZZ4 Crate engine, Accel 24 pound injectors, Accel Superram intake, Accel Large tube runners
SLP 58 mm throttlebody, Edelbrock TES headers, SLP 3" SS exhaust, Random Tech 3" hi flow cat
700R4 trans w/ vette 2/4 shift servo, worked valve body, kevlar band, 2200 rpm stall converter
Borg Warner 9 bolt rear (full poly mounts) Hotchiss panhard rod, Lakewood LCA's, Spohn subframe connectors, custom chip.
Old Jun 6, 2001 | 09:52 PM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
Don't bother getting jacked by Accel on the base. Go to performancepartsonsale.com and order the edelbrock base...there is no difference, especially b/c you really need to portmatch the SR plenum and runners anyway.
Dan
87 IROC-Z, 5.7,auto, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" Jet-Hot coated headers, Accel .219 cam, Comp 1.5 roller tip rockers, $uperPITAram, Edelbrock lower intake, Holley 52mm tb, Dynomax\Flowmaster catback. Coming Soon- DFI or prom burner, Dart Iron Eagle 200cc heads, 6" rod 383 or a 406
1987 Camaro Z28 - 5.2tpi, auto, 3.73s, tb airfoil, ported plenum, !cat, !tbcoolant, !smog, !4th gear :/
1989 Pontiac 20th Anniversary Turbo Trans Am - 161,000 miles, !cat, 9" K&N - SOLD
Old Jun 7, 2001 | 11:25 AM
Mojo's Avatar
<font face="Verdana, Arial" size="2">Originally posted by irocz:
</font>
There is a difference. The Accel base will outflow the Edelbrock in stock configuration. Once they're ported, all bets are off!
408cid 1985 Corvette
http://www.mojosgarage.com
Old Jun 7, 2001 | 11:49 PM
irocz's Avatar
Car: '87 IROC-Z
That's what I'm saying. For what the accel base costs you can get the edelbrock and have it ported to the SR runners and whatever heads you're running. Have you seen any comparisons of the accel to the edelbrock..i.e.- flow numbers? I've eyeballed each and they looked the same, but I didn't have a mic to check the port sizes.
Dan
1987 Camaro Z28 - 5.2tpi, auto, 3.73s, ram air, airfoil, ported plenum, !cat, !tbcoolant, !smog, !4th gear
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
no green
Jan 9, 2016 09:22 PM
mfp189
Sep 27, 2015 09:25 AM
Dragonsys
Sep 25, 2015 03:51 PM
