Bad Vibrations! HELP!!!
Old Jun 6, 2001 | 01:13 PM
Ed1LE's Avatar
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
Okay, I have yet to figure this out. At 60mph I get a horrible vibration that doesn't go away as speed progresses. I've checked pinion angle, driveshaft balance, wheel/tire balance, lift bar adjustments, u-joints, etc. & it's still exactly the same. Any suggestions or ideas before I take it to a frame shop? The car was in an accident over the winter before I bought it, I had a shop install a new front crossmember & control arms (guy hit a steel construction road plate) but vibration is coming through the rear (feels like a bad u-joint). Plus my new Lakewood lift bars are cracking at the axle mounting brackets! Maybe related, I don't know but I'm at my wits end here! Thanks!
'91 Z28 1LE; 355, Sportsman II heads, Edelbrock TPI w/ 58mm TB, Tremec TKO 5-speed, 3.73's & much, much more
Old Jun 7, 2001 | 11:51 PM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
so you've taken the driveshaft and had it rebalanced and replaced the ujoints? sometimes a visual inspection won't cut it. just a thought.
was it vibrating before you put the lift bars on?
69GTOby
Apr 18, 2016 02:34 PM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
sac92transam
Oct 7, 2015 02:31 PM
InfinityShade
Sep 18, 2015 08:32 PM
gta892000
Sep 16, 2015 12:40 AM
