some guy put a 62 MM throttle body on a basically stcok 305
Old Jun 8, 2001 | 12:39 AM
Stormshadow GTA's Avatar
My buddy works at a GM dealership and he help put on a 62 mm throttle body on a basically stock 305,what a freaking bonehead.
1987 Trans AM GTA
305 5SPD
Hypertech airfoil
gutted maf
kn filter
High Flow Cat,
3"Walker pipe
Dynomax Super turbo Muffler
TB Coolant bypass
"Three of the scariest letters you will ever see GTA"
Take a good look you won't see em for long
Old Jun 8, 2001 | 08:39 AM
whiterocz's Avatar
was it your car
Old Jun 8, 2001 | 12:18 PM
Synergy's Avatar
Too bad nobody makes 62 MM throttle bodies for TPIs huh! What a bonehead! lol
Old Jun 8, 2001 | 08:32 PM
they do make one his is a TPI
1987 Trans AM GTA
305 5SPD
Hypertech airfoil
gutted maf
kn filter
High Flow Cat,
3"Walker pipe
TB Coolant bypass
Old Jun 8, 2001 | 08:44 PM
rezinn's Avatar
Um.. so? Sure, it may be unneccesarily large, but thats not gonna hurt anything.(except your wallet)
Old Jun 8, 2001 | 08:48 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
You cannot fit a 62mm throttle blade into the casting, so I'm doubting the story. Perhaps he mis-heard them? They probably installed a 52mm throttle body. "Fifty-two" sounds a lot like "Sixty-two" when used in the vicinity of impact wrenches.
Daniel Burk
View my third-gen hobbyist performance page!
View my reader's ride!
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff., Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Turbine Technologies 2500 stall converter, underdrive pulleys, Crane Hi-6 & more.
1.05g skidpad verified.
Best of 14.039 at 100.82 MPH in Stanton, MI
New! 275-40-ZR17 tires on ROH ZS 17 x 9.5's
Old Jun 9, 2001 | 02:01 AM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
i think its AS&M has a huge a$$ monoblade TPI TB. They use it on BBC blown EFI marine engines for off-shore powerboat races. Little big for a 305.
Old Jun 9, 2001 | 01:29 PM
MATEOZ28's Avatar
The mono blade made by several different company's is said to be between 62 and 66mm's depending wich company it is so he's not wrong.
1992 Trans Am
May 10, 2023 07:19 PM
jhawkeye
May 25, 2022 06:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
justin57
Aug 20, 2015 07:05 PM
