LT1 cam in L98???
Old Jun 8, 2001 | 09:29 PM
dude12387's Avatar
LT1 cam in L98???
ok, my friend bought a 79 camaro, and for some reason got a cam from a LT1 Vette for free with it. hes not using it, so he wants to know if i want it. Will this work with an L98 with TPI????
"When something breaks, it gives me an excuse to replace it with a performace part!"
1988 GTA
TES headers
Flowmaster exaust
TB airfoil
165 Tstat
K+N's
JET chip
kenwood head unit, xplod amp, poineer 3 ways
weird rattling noises
dying 350
crappy paint
700R4 on its last leg
hood that won't open
Old Jun 8, 2001 | 09:59 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
It will work look at my sig. But the LT cam is not that much bigger than the stock L98 cam. I had the peanut cam and it helped alot. I dont think it's worth the time in a L98. Just my .02
87 Z28 305 TPI, Auto, LT-1 cam (@.50 418/430, 194/199, LSA 111), roller timing set, 2.73, Gutted air boxes, K & N fillters, Dyno Max 3" cat back, 8.8 mm spirals, air foil, BFG Drag radials,170* Stat and TB bypass.
Old Best 15.414 @ 87.47.
new best 15.006 @ 89.55.
w/ drag radails 14.6 @ 93
“Fallen But Not Forgotten”
Old Jun 8, 2001 | 11:01 PM
Formula-91's Avatar
That was the first engine mod I did back when I got my 'bird. The lift is a bit more agressive than the L98 cam, but if you're going to do the swap, I'd suggest getting a good aftermarket cam. I only gained 2 tenths from the swap.
91 Firebird Formula. Converted to carb. Holley 750. Forged Flat top pistons. 10.5 to 1 compression. ZZ-9 Cam. Sportsman II Heads.
175 shot NOS, 700r4 w/ 3000 rpm converter and 3.73s in the back. Headers w/ full dual exhaust. 27.5 inch McCrearys.
Old Jun 9, 2001 | 12:24 AM
Beefy89's Avatar
I'm running an LT1 cam in my L98 with 1.6 roller tips.Havent had it to the track yet but it does run better than it did with the L98 cam.
Shoot Shoot!!!!!
Old Jun 9, 2001 | 01:43 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Also check the dowel pin on the front of the cam. The later ones have a longer down pin that will interfere with the timing cover. You need to shorten it to the length of your stock cam. That long pin is there to drive the water pump on the LT1.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Jun 9, 2001 | 03:44 PM
dude12387's Avatar
i know its not radical, and that the best part, cause the engine is about to die anyway, and i dont want to send it to an early grave. the reason is is that its free......would i have to change the lifters, rockers, valves or valve springs wiht this?
1988 GTA
TES headers
Flowmaster exaust
TB airfoil
165 Tstat
K+N's
JET chip
dying 350
crappy paint
Old Jun 9, 2001 | 06:20 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
No you dont have to change a single thing but to see a gain I'd go with the 1.6 RR arms.
Old Jun 11, 2001 | 12:41 AM
Kevin91Z's Avatar
If you use 1.6 rockers you should change the springs.
1991 Camaro Z28
13.23 @ 107.62 MPH
Southern California
Old Jun 11, 2001 | 10:17 AM
Beefy89's Avatar
I went with the ZZ3 springs,around $35 bucks.You will probably need new retainers also.
Shoot Shoot!!!!!
lt500r55
Sep 1, 2021 01:30 PM
midge54
Dec 27, 2019 04:14 PM
italiano67
Aug 31, 2015 06:04 PM
midge54
Aug 29, 2015 09:51 PM
TheExaminer
Aug 19, 2015 10:07 PM
