Intake?
Old Jun 11, 2001 | 02:44 PM
90Iroc-Zee's Avatar
Intake?
Okay, I just ordered my TES Headers/Catback and plan to make another upgrade on my car. I will get an AFPR but for a major mod what should I get? I was thinking of an intake, if even that would be a good upgrade for my setup now. Maybe a cam? I can't get anything like heads because all I have is around $500 to spend. Please let me know, I want to get 13's when I goto US41 in the middle of July, my friends 97 Cobra is running 14.1 and I'm so close I need to whoop his $20k cars *** . Any input would be GREATLY appreciated, thanks.
BTW, I have the G92 package so my cam isn't the peanut cam, it's pretty decent, and if I should get a cam, I need to pull harder in the upper rpms, 1st gear's torque is amazingly strong in my car.
1990 G92 5spd LB9 - 3.42
Accel Ignition/Wires (8.8mm), Advanced Timing, TB Bypass, Ported and Gasket Matched Plenum, Synthetic Motor Oil, 160 Thermo, TPIS Airfoil, K&N Air Filters
14.4 @ 94mph w/2.0622 60ft
Soon To Come
Edelbrock TES Headers, No Cats, Edelbrock RPM Series Catback, AFPR, Underdrive Pulleys, Relocate MAT, Short Throw Shifter, Intake, Cam
Old Jun 11, 2001 | 02:51 PM
irocbsa's Avatar
I don't think you would see much of a benefit from an aftermarket manifold right now, but I'm sure you would see some. People have had varying degrees of success with relatively stock mills. OK, I just looked at the rest of your mods so maybe an aftermarket runner/base combo would work nicelyand compliment the ported plenum. I think SLP still has a special on their runners for $199. A new base is outrageously overpriced (approx $500) so try to find one on ebay or the classifieds on this page. I got my Edelbrock base/Accell runner combo for $400.
Then again maybe look into a set of 1.6 rockers. They should give you a decent amount of extra lift without the cam change.
Good luck.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Edelbrock Intake, Accel Runners, Comp Cam, Crane Gold rockers, Lucas 24# injectors, Edelbrock headers, Flowmaster 3'' exhaust, Mallory Ignition, Transgo Performance Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
jerflash
Sep 24, 2015 03:11 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
