Accel plugs???
Old Jun 12, 2001 | 09:38 PM
Joe's Avatar
Joe
Accel plugs???
I have a 89 formula 350 just wondering the best plugs i am not a gimic person split fire "V" and the other crazy stuff but i was wondering the accel stuff is so good are the plugs any good i already have the extreme 9000 wires and super coil and accel cap but need new plugs
Old Jun 14, 2001 | 12:54 AM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
I have always run autolite/motorcraft plugs and not had any problems. Stay away from the gimmick plugs. They aren't worth the money.
Dan
87 IROC-Z, 5.7,auto, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" Jet-Hot coated headers, Accel .219 cam, Comp 1.5 roller tip rockers, $uperPITAram, Edelbrock lower intake, Holley 52mm tb, Dynomax\Flowmaster catback. Coming Soon- DFI or prom burner, Dart Iron Eagle 200cc heads, 6" rod 383 or a 406
1987 Camaro Z28 - 5.2tpi, auto, 3.73s, ram air, airfoil, ported plenum, !cat, !tbcoolant, !smog, !4th gear
1989 Pontiac 20th Anniversary Turbo Trans Am - 161,000 miles, !cat, 9" K&N - SOLD
Old Jun 14, 2001 | 03:29 PM
FormulaJoe's Avatar
DO NOT BUY ACCEL PLUGS. Man, I had bad luck with the ones I bought. The ends of them screw on (the end the plug wire goes on) and all of a sudden, these things all decided to come UNSCREWED all at once and the car was running like A$$. I would screw them back in and it would run fine for a while, then same thing again.
I have been running NGKs. They are cheap and I have not had any problems with them. Ive got probably 20-25K on the ones in my 88.
L98, 3.27 9-bolt, Hooker shorty headers, custom 2.5inch Y-pipe, no cat, 3inch 2chamber flowmaster, JET AFPR, Ported MAF, Best ET: 13.86 @100mph. 1.99 60'
17 inch ROH "ZS" wheels. 17x8.5(front) and 17x9.5 (rear). Firestone Firehawk SZ50s. 245/45/zr17s and 275/40/zr17s. T56
On the way... Radar Blue 89 Formula, T56, Ram Jet 430, Ram Air, 17inch ROHs.
Old Jun 14, 2001 | 03:42 PM
rezinn's Avatar
The tips of all spark plugs screw off.. you just have to tighten them and they should never bother you.
Old Jun 14, 2001 | 03:52 PM
91-ZZ4-Z28's Avatar
They are not that bad and they don’t cost much more that other plugs. I had a set of there shorty plugs (I had a header clearence problem) and I got good use out of them. They are made by Nipendenzo a Japanese company that makes many factory plugs for imports.
1991 Z28 ZZ4 with LPE superram base, SLP runners, LPE 58mm T-body,Random Technology ramair,TES headers,24#svo injectors,and just about every other bolt on that there is. Just got a ZEX nitrous kit!
gta892000
Aug 11, 2019 11:16 AM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
BAMiller
Sep 14, 2015 06:38 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
