Real world performance improvements from advancing timing up past 6* BTDC
Old Jun 12, 2001 | 01:56 PM
Steve91Z28 L98's Avatar
Car: 1991 Camaro Z28
I checked my timing a couple days ago and it was way off (too retarded) so I adjusted it back to 6* BTDC and the difference is like night and day. It literally feels like I freed up at least 30 hp. The car was definitely not running to its fullest potential before. The car has ***** that I never knew it had before. My question is this: What kind of improvements can be expected from advancing the timing to say 8* BTDC? Is it really a seat of the pants improvement or is it just a few hp? I've even heard of people advancing it as far as 10* BTDC. Is this too much? Thanks in advance.
1991 Z28 - 350 TPI, T56, McLeod street clutch, LT4 pressure plate, Pro 5.0 shifter, ported plenum & runners, AFPR, Holley Annihilator ignition box and wires, Hooker shorty headers w/o AIR, Flowmaster muffler, homeade ram-air, SSM subframe connectors, Kenny Brown STB, Global West steering box brace, Steve Spohn adjustable torque arm and T56 crossmember
Old Jun 12, 2001 | 02:11 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I just moved from 6* up to 10* and dam I felt a differance. It smokes them when chirping into 2nd. It never broke loose like that before at 6*
Old Jun 12, 2001 | 02:21 PM
Hell yeah then I may go try it out tonight. Before I adjusted it to 6* I could barely do a burnout but now I have trouble keeping traction. And I could never chirp the tires going into second but now I can. If I can make them break loose going into second from advancing the timing more, I think I will mess my pants. Well I probably don't have quite enough power to do that with my current setup. When I get my 3.73's in the next couple of weeks I bet I'll be able to do it. Anyone else with real world testimonials or advice on this? Thanks
Old Jun 12, 2001 | 04:46 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I'd suggest going in 2* increments...FWIW my car rattles like crazy at anymore than 6*'s BTDC.
Old Jun 13, 2001 | 11:02 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
I have real proof of what happened for my car. This was done at a performance shop on their dyno testing at the rear wheels.
I had mine set to 8* ran it on the dyno, then set it back to 5* and there was almost NO difference. The curves were nearly identical and peak HP and TQ were just about the same.. within .5 of each other.
Of course that is just my car. Results will vary.
1987 IROC, basically stock, with 160,000 miles on it. It had 191 HP and 281 TQ at the wheels, and just ran a best of 14.72 @ 92.
Member of The Connecticut F Body Association
1987 IROC 5.7 - 14.72 @ 92
1988 Formula
1986 Z28
Old Jun 14, 2001 | 08:01 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
I would not go much past 8 deg without looking at a scanner. You want to see if the computer is pulling timing out due to knock counts. However if you have an Adj FPR you can compensate some for this buy pushing the fuel pressure up. Just don't go too far and lean it out and burn a piston.
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Infested
May 22, 2018 11:56 PM
Andrew6.688
Dec 13, 2015 10:59 AM
86IROC112
Aug 17, 2015 02:00 PM
novaderrik
Aug 10, 2015 12:44 PM
Thirim
Aug 9, 2015 06:19 PM
