Ramjet or TPIS miniram manifold
Old Jun 14, 2001 | 02:34 PM
need4speed's Avatar
For a 350 cubic inch motor (basically a zz3 bottom end and cam with vortec heads) which would be a better choice. TPIS miniram or the GM ramjet?
What are the flow number and rpm ranges for these manifolds???
That brings up another question, does anybody know the flow numbers for the ZZ3 and vortec heads?? Or where to find them??
Old Jun 14, 2001 | 03:05 PM
FormulaJoe's Avatar
Its hard to say because there has'nt been a whole lot of testing done with this intake to see what it likes in a motor. The mini ram is an excellent intake, but it may be a little too much for your application. The MR usually likes a large engine or a smaller one that spins some serious RPM. With the relatively small ZZ4 cam, you may not be fully utilizing the capabilities of that manifold.
The ram jet may be a better choice, it has slightly longer runners (ram jet is ~4.25in and MR is ~3in) which may be better for your application, but availability of parts for the ram jet is not that great yet.
L98, 3.27 9-bolt, Hooker shorty headers, custom 2.5inch Y-pipe, no cat, 3inch 2chamber flowmaster, JET AFPR, Ported MAF, Best ET: 13.86 @100mph. 1.99 60'
17 inch ROH "ZS" wheels. 17x8.5(front) and 17x9.5 (rear). Firestone Firehawk SZ50s. 245/45/zr17s and 275/40/zr17s. T56
On the way... Radar Blue 89 Formula, T56, Ram Jet 430, Ram Air, 17inch ROHs.
Old Jun 14, 2001 | 03:08 PM
IROC5.7TPI's Avatar
I have to go along with the Ram Jet.
It seems to be a better choice for milder applications, as well as the cutting edge in design.
Mike L.
"If it feels good - stay in it "
1987 IROC Z TPI 350 A4 3.27 Borg-Warner.
Mods: 2300-2500 Stall Converter, Shift Kit(GM parts), TPI Specialties Stage 3 PROM, Modified Airbox w/ K&N's, Relocated MAT sensor, Gutted MAF, Accel 8mm Wires, bypassed TB coolant, Flowmaster 3 chamber single 3" in/out muffler, airfoil, Random Tech Hi-Flow Converter (soon to go byebye!). ALL STOCK otherwise.
http://www.MichaelLasiuta.home.att.net
**BOYCOTT LAPEER DRAGWAY**
Old Jun 14, 2001 | 11:01 PM
need4speed's Avatar
Thanks, that is what I was leaning towards also.
How much different internally is the miniram from the LT1 intake. I think the runners are the same length, but what about port/chamber volume???
Thanks.
LT1Formula
20
Nov 14, 2015 12:02 AM
Hawkeye1980
Aug 31, 2015 07:09 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
