ATTN: Joseph@SDSC
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
ATTN: Joseph@SDSC
I noticed your RamJet setup on your formula. Does that fit under the Stock Hood???
I like my stock hood and wonder if there are any clearance problems to be considered.
87 Formula 5.1 converted to TPI Yellow/Black
SLP cam, headers, cat-back exhaust
Ported & polished TPI intake
Gil Younger (no yo-yo) Shift Kit
Aluminum Driveshaft
3.73 Posi gear
Baer 12" brakes 4 wheels
KYB AGX Adjustable Shocks & struts
Hotchkis strut tower brace
South side machine frame connecters
Custom reinforced control arms and pan hard bar.
Custom Leather interior
CUSTOM Yellow Gauge Faces
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro (Parts)
83 T/A (parts)
http://www.3rdgenformula.com
Aluminum Driveshaft
3.73 Posi gear
83 Camaro (Parts)
83 T/A (parts)
Thats actually my Ram Jet Formula. Joseph just posted the pictures up for me. Well, thats the big mistery about the hood clearance on a stock hood. We know it will clear a stock Camaro hood, but not too sure about a Firebird hood. I have a Ram Air hood on my Formula and it clears with no problems at all. I think it will be very close on a stock powerbulge formula hood.
L98, 3.27 9-bolt, Hooker shorty headers, custom 2.5inch Y-pipe, no cat, 3inch 2chamber flowmaster, JET AFPR, Ported MAF, Best ET: 13.86 @100mph. 1.99 60'
17 inch ROH "ZS" wheels. 17x8.5(front) and 17x9.5 (rear). Firestone Firehawk SZ50s. 245/45/zr17s and 275/40/zr17s. T56
On the way... Radar Blue 89 Formula, T56, Ram Jet 430, Ram Air, 17inch ROHs.
hmm, ok, it does look like it will be close, Actually, Joe, How difficlut would it be to measure from the base of the intake to the top of the throttlebody in the front, the Stock TPi is almost exactly 8"
John
Aluminum Driveshaft
3.73 Posi gear
83 Camaro (Parts)
83 T/A (parts)
John
Aluminum Driveshaft
3.73 Posi gear
83 Camaro (Parts)
83 T/A (parts)
Ill do that. I measured it one time and it was almost exactly the same. It wasnt a very accurate measurement though. Ill measure the ram jet and the TPI tonight after I get off work and try to get an accurate measurement.
Kewl, Thanks Joe...
Aluminum Driveshaft
3.73 Posi gear
83 Camaro (Parts)
83 T/A (parts)
Aluminum Driveshaft
3.73 Posi gear
83 Camaro (Parts)
83 T/A (parts)
Same name, different Joe, different car
-Joseph
ASE Master Automobile Technician
Scoggin-Dickey Chevrolet
1967 Camaro (Vortec Heads, GM Vortec Intake, ZZ4 roller camshaft) --- Planning T-56 Install in the near future
1992 Firebird (Weiler Vortec Heads, LT4 Hot Cam, GM Vortec Intake, 3000 Stall, 3.73's, Auburn Posi)
-Joseph
OK, I did some measuring last night. The ram jet intake and the TPI are close. However, the TPI slopes down toward the front for added clearance. The ram jet does not. The two intakes were exactly the same at the rear of the intake, but at the front up by the TB, the ram jet was 1 inch taller. So, I took a socket (about 1inch tall) and set it on top of my TPI car to see if it would clear the power bulge hood or not. Well, the hood shut. But remember, the Ram Jet manifold is like 3 inches wide at the top as opposed to the socket I used which was like 9/16 or whatever.
My opinion: I think this thing will work with a power bulge hood. I think it might come down to removing/cutting some of the crossbracing under the hood right above the TB.
Sounds close, I currently have a Hotchkis strut brase that is about one inch higher as well, it actually rubs on the hood liner, but does not make contact with the hood itself. I bet there is enough clearance (Barely) the cold air tubes from the MAF might have to be forced downward, but I bet it would work...
Thanks Joe...
Aluminum Driveshaft
3.73 Posi gear
83 Camaro (Parts)
83 T/A (parts)
Thanks Joe...
Aluminum Driveshaft
3.73 Posi gear
83 Camaro (Parts)
83 T/A (parts)
oh, almost forgot to ask,
About what diameter is the throttle-body, it looks to be around 3"
John
Aluminum Driveshaft
3.73 Posi gear
83 Camaro (Parts)
83 T/A (parts)
John
Aluminum Driveshaft
3.73 Posi gear
83 Camaro (Parts)
83 T/A (parts)
The TB is about 3.5 inches in diameter.
patricktroyz28
Aftermarket Vendor Review
Dec 31, 2006 02:37 PM
