My planned Miniram setup will now be a balanced LTR system!
Old Jun 14, 2001 | 05:54 PM
MelloYello's Avatar
In an earlier post entitled "My Miniram" I talked about merely swapping out my stock intake for a miniram untill I could afford a new motor - bad idea...too expensive...period. Instead, I came across a series of great deals to get me on my way to building a performance, budget oriented LTR setup:
Like new Edelbrock baseplate and runners - old base and runners + $325 trade
Trickflow L98 angle plug heads assembled with mild port job and large valves ran only few dyno runs - $750
Heads and intake - $1075 = less than Minram and fuel rail kit and more power to boot!
If I can post the flow #s from the port job, could you reccomend a cam for me to use with 1.6/1.52 rr? I plan on matching my intake to my heads as far as flow is concerned and plan on breaking into the 12s. I have 3.73s and will get a vigilante converter with at least 2500 stall. Any comments and tips will be much appreciated! Thanks!
Kyle
1990 Firebird Formula 350 speed density TPI; K&N, air foil, throttlebody coolant bypass, underdrive pullies, MSD 6AL, MSD HEI coil, 8.8mm wires, , Hypertech Stage II chip and AFPR, 160* thermostat, fan switch, B&M stage 2 shift kit, Edelbrock 1&5/8 headers, !Cats, !AIR, Flowmaster 80 series muffler, 3.73 posi rear end
[This message has been edited by MelloYello (edited June 14, 2001).]
Old Jun 14, 2001 | 06:12 PM
MelloYello's Avatar
Also, I don't care about emissions, I have gutted cats, removed my smog pump and hoses and will be registering my car to a P.O. box in an emissions exempt area. I want a cam that will create the best power with my setup, but I want that choppy sound without my ecm going berserk with codes.
Kyle
Old Jun 15, 2001 | 12:15 AM
BC86TPI-Z51's Avatar
Sounds great to me...a good LTR set up with heads,exhaust, and cam will make around 350 horses or so..and torque will be incredible..I feel youre going to have traction problems to the extreme.
Great combo nontheless.
Old Jun 15, 2001 | 08:02 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Get that lower intake fully ported and maybe get your runners extrude honed for more flow.
lt500r55
Sep 1, 2021 01:30 PM
stalkier
Dec 6, 2015 11:25 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
gta90
Sep 15, 2015 04:00 PM
Street Lethal
Aug 13, 2015 08:28 PM
