cruise control probs on L98
Old Jun 14, 2001 | 02:07 PM
whiterocz's Avatar
ive checked all the vacuum hoses and they are all ok. the cruise will not turn on at all. is there some way i can check the servo to see if that is the problem or if my set switch is broken. also could it have something to do with a switch on the brake pedal?
Old Jun 15, 2001 | 03:40 AM
kane91z's Avatar
Car: 91 Z28
Engine: 5.7
it could be the sensor in the brake (and or clutch if you have a manual) that was my problem a while back
91 z28 lb9 5 speed - hooker 1 5/8 headers - high flow cat- full 3 inch exhaust - home made ram air - tpis airfoil - dual chamber flowmaster - Stage 2 Jet Chip and 160 stat - 8 mm Msd plug wires - 55,000 v hypertech coil/rotor/distrib. cap - Mac. White face gauges - lots of sound system crap...
Old Jun 15, 2001 | 07:59 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
The switch on your turn signal lever is, honestly a piece of crap, its fraginle, and easily broken for no apparent reason. When I bought my first 87 formula the switch was broken inside... There are 4 wires going to the switch, there is a plug found under the dash, You will have to pull the plastic cover and remove its interior light.
Looks kind of like from the side, mine was kind of whitish if I remember
________
<img border="0" src="http://www.tir.com/~jazofko/images/cruiseplug.jpg" width="423" height="135"></p>
there are 4 contacts, two on each side of the plug, thus there are 4 wires, Green, Yellow, Blue, & Red,
Giving each color a number:
Yellow = 1
Green = 2
Red = 3
Blue = 4
The Green wire is on this side Top, yellow is on other side Top.
Blue is this side bottom & Red is other side bottom.
O = Open
C = Closed
With an Ohm meter check the following conections:
<table border="1" width="100%">
<tr>
<td width="12%" align="center" rowspan="2" bgcolor="#C0C0C0">
<p style="margin-top: 0; margin-bottom: 0">set/Coast</p>
<p style="margin-top: 0; margin-bottom: 0">S/C switch </td>
<p style="margin-top: 0; margin-bottom: 0"> position </p>
<p style="margin-top: 0; margin-bottom: 0"> Slider</td>
<td width="76%" align="center" colspan="6" bgcolor="#C0C0C0">TERMINALS ON
THE PLUG</td>
</tr>
<tr>
<td width="12%" align="center" bgcolor="#C0C0C0"> 1-2 </td>
<td width="12%" align="center" bgcolor="#C0C0C0"> 1-3 </td>
<td width="13%" align="center" bgcolor="#C0C0C0"> 1-4</td>
<td width="13%" align="center" bgcolor="#C0C0C0"> 2-3</td>
<td width="13%" align="center" bgcolor="#C0C0C0"> 2-4</td>
<td width="13%" align="center" bgcolor="#C0C0C0"> 3-4</td>
</tr>
<tr>
<td width="12%" align="center" bgcolor="#FFFF00">Normal </td>
<td width="12%" align="center" bgcolor="#FFFF00"> Off </td>
<td width="12%" align="center" bgcolor="#FFFF00"> O </td>
<td width="12%" align="center" bgcolor="#FFFF00">O</td>
<td width="13%" align="center" bgcolor="#FFFF00">O</td>
</tr>
<tr>
<td width="12%" align="center">Normal </td>
<td width="12%" align="center"> On </td>
<td width="12%" align="center">O</td>
<td width="13%" align="center">O</td>
<td width="13%" align="center">C</td>
</tr>
<tr>
<td width="12%" align="center" bgcolor="#FFFF00"> R/A</td>
<td width="12%" align="center" bgcolor="#FFFF00">C</td>
<td width="13%" align="center" bgcolor="#FFFF00">C</td>
</tr>
<tr>
<td width="12%" align="center">DEPRESSED </td>
<td width="12%" align="center"> OFF </td>
</tr>
<tr>
<td width="12%" align="center" bgcolor="#FFFF00">DEPRESSED </td>
<td width="12%" align="center" bgcolor="#FFFF00"> ON </td>
</tr>
<tr>
<td width="12%" align="center"> R/A</td>
<td width="12%" align="center">C</td>
</tr>
</table>
I hope this helps and is not to much informaiton...
John
87 Formula 5.1 converted to TPI Yellow/Black
SLP cam, headers, cat-back exhaust
Ported & polished TPI intake
Gil Younger (no yo-yo) Shift Kit
Aluminum Driveshaft
3.73 Posi gear
Baer 12" brakes 4 wheels
KYB AGX Adjustable Shocks & struts
Hotchkis strut tower brace
South side machine frame connecters
Custom reinforced control arms and pan hard bar.
Custom Leather interior
CUSTOM Yellow Gauge Faces
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro (Parts)
83 T/A (parts)
http://www.3rdgenformula.com
[This message has been edited by okfoz (edited June 15, 2001).]
Old Jun 16, 2001 | 09:24 AM
whiterocz's Avatar
hell yeah, when you ask for help on this forum, thats the kind of response you should get. thanks alot bro.
Hotrodboba400
Dec 10, 2019 07:07 PM
scottmoyer
Sep 7, 2015 07:06 PM
dbrochard
Sep 7, 2015 09:41 AM
Jlanz55
Sep 6, 2015 02:35 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
