why did it not help??
Old Jun 17, 2001 | 05:31 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Transmission: working
Axle/Gears: both
Hi,
Old Jun 17, 2001 | 06:33 PM
Vader's Avatar
GTA,
That's no a huge surprise. Unless you do some PROM reprogramming, the ECM is going to trim fuel and spark just as if nothing had changed. That is one of the weaknesses of the speed-density control scheme. You're probably getting all kinds of good air flow with the new can and no extra fuel to compensate, so you are running lean, hot, and powerless.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Jun 17, 2001 | 07:20 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I kinda have to disagree. If a larger cam is installed, it will open the valves further and hold them open longer, allowing more airflow into the cylinder. This would cause a lean condition, but the fuel trim capabilites of teh computer would adjust and add more fuel.
I think where he is hurting is that the cam is capable of allowing more air to flow, but either the intake, exhuast, or a combination of both is negating any benefits that the cam may have made.
What other mods does your friend have? Definatly want to open that exhaust up some.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Old Jun 17, 2001 | 10:14 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Axle/Gears: both
Guy's
Old Jun 17, 2001 | 11:55 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Well, could be a few things, maybe too much cam for the reargears to handle down low in the RPM band, along with the need for some tuning.
An AFPR should help with a fuel issue.
Old Jun 18, 2001 | 02:56 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
I thought all GTA's were 350 / A4, or 305 / M5 not 305 / A4. Plus, with GTA's being very much "loaded" why wouldn't a 1991 have G92 and thus dual cats?
jmd
L69 / T5
Old Jun 18, 2001 | 03:13 AM
AUTOGON350's Avatar
Car: 93 S10 blazer
I just put a 350 in a 1990 TA with a nice cam and heads and the 2.73 gears are killing the whole thing. Yea 5,000 bucks for nothing. I would look to the gears first.
1990 TA 350 TPI
SPORTSMAN II HEADS
COMP CAMS 224-230@.50
52MM THROTTLE BODY
24LB INJECTORS
Old Jun 18, 2001 | 11:08 PM
whiteroc's Avatar
What are the specs on the cam? The gears have gotta go. You need at least 3.23s or 3.42s with most mild aftermarket cams not to mention the need for a higher stall speed from the torque converter. The stock Corvette converter may be just right for your combo with better gears- but even if you opt not to get the gears get the higher stall speed converter.
On a Speed Density car you really need to get a prom burned for your exact application and tune with the fuel pressure from there. FYI -The Mass Air cars can handle about a 15% increase in airflow unlike the SD setup.
Again -about the cam... remember this -The more duration a cam has the higher the RPM at which it will make power and torque -hence the need for the gears and higher stall speed <-- this is all needed just to get the engine into it's "new" power band.
89 IROC-Z 5.7L
130,000 MILES
2.77 GEARS
K&Ns FILTERS
ALL FREE MODS
FLOWMASTER MUFFLER
PERFORMANCE RESOURCE CHIP
Best 1/4 E.T. 14.37 @ 95 MPH
Best 1/8 E.T. 9.22 @ 76 MPH
Best 60ft. 2.07
Old Jun 19, 2001 | 08:56 AM
IROC5.7TPI's Avatar
I'm agreeing with Vader on this one.
A SD computer will not make real-time adjustments to compensate for the over-lean condition the cam has created. SD has no adaptive learning like MA does.
Get a PROM burned, a gear in the rear, and a tuner who knows WTF he's doing.
That was a bad idea in the first place replacing the cam. I would have spent the time/money on more effective bolt-ons first.
Good luck....
Mike L.
"If it feels good - stay in it "
1987 IROC Z TPI 350 A4 3.27 Borg-Warner.
Mods: 2300-2500 Stall Converter, Shift Kit(GM parts), TPI Specialties Stage 3 PROM, Modified Airbox w/ K&N's, homemade cold air, Relocated MAT sensor, Gutted MAF, 160* thermostat, Accel 8mm Wires, bypassed TB coolant, Flowmaster 3 chamber single 3" in/out muffler, 3" MAC mandrel intermediate, custom dual !cat Y-pipe. airfoil, ported plenum. !smog
http://www.MichaelLasiuta.home.att.net
**BOYCOTT LAPEER DRAGWAY**
