Making custom 3" Runners
Old Jan 7, 2008 | 10:59 PM
hardcoreZcar's Avatar
Car: 86 Z
Engine: 400 sbc
Transmission: t-56
Axle/Gears: 4.10
I am about to start the fabrication of new runners using the old flanges. I plaqn on using a siamesed type setup where i will use an aluminum 3" u bend to carry the intake of two stock tubes and will oval the ends to fit within the flange. Has anybody ever tried this? Any words of advise before i get started? Thanks guys...
Old Jan 8, 2008 | 04:11 AM
kanmudhog's Avatar
Car: 89 formula ws6
Engine: yes
Transmission: yes
Axle/Gears: both
Re: Making custom 3" Runners
I'm been polishing on mine all weekend , mind numbing task , and I've had a few ideas .
They make a see thru polycarbonate diff cover for dana 60s and corperate 14 bolts , really cool to see the ring and pinion , but more important it can handle the heat .
Ok so I know they make polycarbonate tube in different diameters and with a high temp pad it can be formed , so the shape of the runner would be no problem .
The problem is sealing the ends , I think the end would need to be flared like a brake line and then the stock flanges would need to be milled to whatever angle to match the flare and then an o ring would seal around that .
Why go to all this trouble , depending on the tube sizes available you might be able to increase the diameter of the runners , you could also then drill and tap a hole in the plenum to mount a strobe or colored LEDs .
It's either a cool idea or I've just inhaled to much aluminum dust and my brain has shorted out .
Old Jan 8, 2008 | 11:54 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
I was thinking that you could take the exsiting runners and cut the inside half of both of the tubes and weld a plate all the way down the center of the two tubes making a mono tube on both sides
I wish I could paint you a pic I am sure that some of you out there can imagine it
I have also thought about taking a brake hone and putting cutting stones on the ends and hookin up a stock intake
Old Jan 8, 2008 | 04:50 PM
cwyates4's Avatar
Car: 85 vette/87 TA
Engine: built 383/350 tpi
Transmission: built 700r4s
Axle/Gears: 3.45 dana 44/ 3.27 9 bolt
"I was thinking that you could take the exsiting runners and cut the inside half of both of the tubes and weld a plate all the way down the center of the two tubes making a mono tube on both sides."
I've seen this done on ebay before, looked not so great, but im sure it made for a decent power upgrade.
Old Jan 8, 2008 | 07:24 PM
Car: 86 Z
Engine: 400 sbc
Transmission: t-56
Axle/Gears: 4.10
Yea, ive seen the tubes welded together but it looked terrible. I want to polish them and like the sound of the quad long tube design.
Old Mar 11, 2008 | 08:48 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Getting these to mate up exactly is going to be rough. I was going to have my set of runners siamesed using the aluminum from some old TBI ecm's but the guy doing the welding was paranoid they would warp from the heat of welding and never line up/seal correctly.
Old Mar 11, 2008 | 09:17 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I have done some research in this area. What I was looking at was using aluminum 2.00" diameter u-bends with a 3" radius. These are readily available with a .062" wall thickness. One could siamese them any length to get the length of runner you would need for your combination.
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
tazs2000
Jul 15, 2017 08:44 AM
87iroctheo
Dec 4, 2016 11:47 AM
Hawkeye1980
Aug 31, 2015 07:09 AM
