LT1/LS1 350 engine block
Old Mar 7, 2008 | 07:20 PM
firebird896's Avatar
Car: '89 GTA/'86 TA/98 TA
Engine: 350/350/LS1
Transmission: R4/T5/4L60E
Axle/Gears: 3.23/2.77/3.73
I was thinking of getting a 350 4th gen block and putting a the TPI set-up on it. Will this work or is it entirely different?
Old Mar 7, 2008 | 07:30 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Re: LT1/LS1 350 engine block
gen 1(tpi) heads will not work on a LS1 block...way different.
not sure about the LT1 block....the timing area is different i believe plus the stuff for the cooling so i pretty sure it can't be used.
Old Mar 7, 2008 | 07:51 PM
Engine: 350/350/LS1
ok I can scatch that idea then.
Old Mar 7, 2008 | 09:42 PM
Abubaca's Avatar
Yeah, the LS1 stuff is totally different.
The LT1 stuff is REAL close, and with a LOT of custom work, technically it is possible to do, but certainly not for the "average" joe. Consider it not possible. The fartherst I think anyone has really taken it has been LT1 heads on a traditional 350 block.
Old Mar 8, 2008 | 05:17 AM
Brian Esser's Avatar
Car: 1996 Chevrolet S10
Engine: 350 LT1
Transmission: TH350
Axle/Gears: 3.08:1
Don't forget Gen 1 heads on the LT1/LT4. it can be done with some machine work as well. Several of the high dollar racers running LTx's do the swap.
Old Mar 8, 2008 | 05:26 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
LS1 fuel injection is so much better than TPI anyway, it'd be foolish to bother.
Old Mar 8, 2008 | 10:45 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Old Mar 9, 2008 | 01:27 AM
Pocket's Avatar
Car: 91 Trans Am
Go with the 411 PCM and gain all the benifits of the LS1 EFI
Old Mar 9, 2008 | 10:07 PM
sprslo92's Avatar
Car: 92 z-28 vert heritage edition
Engine: LT-1
Axle/Gears: 3.08 posi
I would go with the ls1 because the lt1 a pain in the a@#. Ive been helping my friend with his 4th gen for the past four weeks and im ready to put a bullet through the block.
Old Mar 9, 2008 | 11:13 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
What kind of problems are you having?
Jake
Old Mar 10, 2008 | 01:35 AM
Engine: 350 LT1
Transmission: TH350
Axle/Gears: 3.08:1
Plugs and wires are harder on the LT1 vs the LS1.
Old Mar 10, 2008 | 08:26 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Our technology is exceeding our limits of understanding.
Some of this stuff is a real PITA.
Carb, CC Carb, TBI, TPI, OBD-1, OBD-2, ABS, Trac Control, Fly by wire, Heads up display, Electronic anything, SC, Turbo, L98, LT1, LS1, 2, 3, 4, 5, 6, 7, 8, 9, and on and on........
Old Mar 10, 2008 | 10:31 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
If you have to ask this question... you are not ready for the type of custom work or this type of task...
Old Mar 11, 2008 | 03:16 PM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Some of these cars sound like Johnny Cash's Caddy.
Old Mar 11, 2008 | 11:13 PM
Engine: 350/350/LS1
It was just a question and I was just curious
Jake_92RS
Jan 28, 2020 10:37 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
lakeffect2
Aug 23, 2015 08:44 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
