T-5 trans rebuild time
Old Jun 15, 2001 | 11:41 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I have a 91 GTA w/ a ZZ4 crate under the hood. I want to rebuild my trans. I think I'm going to need new gears. How do I go about getting them?
Old Jun 18, 2001 | 02:25 AM
age's Avatar
age
Car: 1992 Z28 1LE
I believe the web addy is www.5speeds.com, or www.gearzone.com (I think they both lead to the same site.. can't remember). I just got mine a couple of months ago, and Karl Hunter (Hunter Motorsports) just put it all together for me today (I watched and was the learning apprentice). The rebuild kit is awesome. It comes with everything you need to do a full rebuild (doesn't come with gears). The replacement parts completely identical, from the same manufacturer as the ones you'll be replacing. Had no problems that are normally associated with "universal fit" parts.
If I were you, I would also order the 5th gear stabilizer plate. It's about $50 more, but when you compare it with the stock one, you'll know that it was worth the $50.
I think total was about $200US before shipping/tax/etc..
Old Jun 18, 2001 | 05:13 AM
kane91z's Avatar
Car: 91 Z28
Engine: 5.7
those links don't won't... one gives me nothing and the other is a out doors gear place
91 z28 lb9 5 speed - hooker 1 5/8 headers - high flow cat- full 3 inch exhaust - home made ram air - tpis airfoil - dual chamber flowmaster - Stage 2 Jet Chip and 160 stat - 8 mm Msd plug wires - 55,000 v hypertech coil/rotor/distrib. cap - Mac. White face gauges - lots of sound system crap...
Old Jun 18, 2001 | 09:43 AM
Brian Shaughnessy's Avatar
Car: '89 Formula
Engine: 355 TPI
Axle/Gears: 3.70 9 bolt.
OK, try these links:
http://www.5speeds.com/
http://www.gearzone.net/
'89 Formula - Thunderchicken - 355 Vette L98/T-56/3.45 9-bolt/black/t-tops - the fun car!
'90 GTA - The GTA - 5.0 LB9/TH700/3.27 9-bolt/black/t-tops/tan leather - the cruiser.
Old Jun 21, 2001 | 02:28 AM
kane91z's Avatar
Car: 91 Z28
Engine: 5.7
thanks!!!
Old Jun 21, 2001 | 11:44 AM
camaro6spd's Avatar
you are in the wrong forum, there is a special trans/suspen/brakes forum.
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
jharrison5
Aug 19, 2015 05:53 PM
Exxon Limited
Aug 9, 2015 08:13 PM
hokis
Aug 9, 2015 03:57 PM
