siameese intake
Old Jun 20, 2001 | 07:52 PM
AUTOGON350's Avatar
Car: 93 S10 blazer
siameese intake
will a siameese intake base require any ECM calibration? I was thinking about opening up my stock base but I just had a chip made and I would like to avoid changing it again That stock manifold has to go some way or another.
1990 TA 350 TPI
SPORTSMAN II HEADS
COMP CAMS 224-230@.50
52MM THROTTLE BODY
24LB INJECTORS
Old Jun 20, 2001 | 10:07 PM
whiterocz's Avatar
no you wouldnt have to mess with your computer. i know what you mean about the base, im getting tired of runing out of power at 4800rpm when everyone else is making usefull power all the way up to 6-6.5 grand.
Old Jun 21, 2001 | 05:20 PM
AUTOGON350's Avatar
Car: 93 S10 blazer
I hear that with some grinding the stock base is almost as good as the TPIS big mouth manifold so I think that Im going to tear into mine next week.
The way these heads and cam are it looks like my only chance for power will be at the top.
1990 TA 350 TPI
SPORTSMAN II HEADS
52MM THROTTLE BODY
24LB INJECTORS
Old Jun 21, 2001 | 07:15 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
Do people really siamese the intake base? Seems counter-intuitive.?????
1991 Firebird
350 L98 (was a 305 TBI)
T-5 transmission
Edelbrock TES and cat back
Accel manifold
NOS
subframes
jegster torque arm
MSD Digital 6
AFPR
Lakewood lcas
Hurst linelock
SLP cam (206 212 .480 .486)
relocated battery
cold air
Hypertech chip
centerforce df clutch
poly bushings and mounts
AFR 190s
Harland sharp 1.5 rockers
a/f gauge
autopower rollbar
12.44 @ 114.63 juiced uncorrected
13.549 @ 102 non juiced uncorrected
Old Jun 21, 2001 | 11:01 PM
Guest
Guest
Posts: n/a
I dunno about 'people', but I did... and picked up 20hp/15tq with zero tuning and only the base modification, no others. Read about it here:
https://www.thirdgen.org/messgboard/...ML/001492.html
The next slew of mods are still in progress, and I am still trying to decide on a diagnostic program so I can tune it properly.
I am gonna say it will run and you will pick up a little power without changing the chip, but ideally you want a different chip. You should look into programming your own, its not that difficult to do, and the results are much better than any chip ordered over the phone.
Old Jun 22, 2001 | 06:46 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
GofasterFirebird?do you ever have anything usefull to say?
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://discussion-board.com/GreaterC...dyAssociation/
http://www.cincyspeed.com/
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
jerflash
Sep 24, 2015 03:11 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
