TB external return spring??
Old Jan 9, 2008 | 10:24 PM
Teds92RS's Avatar
Car: 1989 Camaro IROC-Z
Engine: Lt1
Axle/Gears: Quick performance 9" 4.11
Anyone make an external return spring in addition to the factory setup for the TB return? I'm having an odd problem, after recently cleaning my TB and replacing the sensors, my throttle sits higher than normal while driving and if I rev the car the rpm's will drop back down to about 1500 and stay there. I have to get out and push the throttle maybe 1/16" to 1/8" back to the tab so the rpm's drop. With the car off I can manually turn the throttle open and it springs back to where it should. All my lines are oiled and do not bind. While driving if I let off the gas the rpm's will not drop under 1000 until I come to a stop and the trans downshifting forces the rpm's down. Any ideas?
Old Jan 10, 2008 | 06:02 AM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: TB external return spring??
sounds like throttle blades are sticking. mine did it .i took a small piece of emery cloth and opened the blades ,cleaned the body ,and edge of the blades.one of the blades had a burr on it .good luck jimmy
Old Jan 10, 2008 | 11:55 PM
Teds92RS's Avatar
Engine: Lt1
I'll have to give it a try, thanks.
Old Jan 14, 2008 | 07:06 PM
Teds92RS's Avatar
Engine: Lt1
that seems to have been it, I did that and it's been running great, thanks again!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
87v6Bird
Jul 1, 2018 04:12 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
sandman92084
Sep 12, 2015 10:27 PM
lakeffect2
Sep 7, 2015 03:52 PM
