305 or 350?????
Old Jun 23, 2001 | 10:07 AM
KoryVett's Avatar
305 or 350?????
I just bought a 86 Z28 w/ a tpi swaped in. The guy I bought it from said he was sure the previous owner put a 350 in but I have my doubts. Are there any easy ways to tell. Maybe part number on something like MAF. Thanks for the help.
Old Jun 23, 2001 | 10:48 AM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
unfortunatly there isnt aall small block chevys are the same except the 400 and the older late 50's engines however if you could squeeze in there on the pass. side of block where the tranny bolts up it will say what engine it is i.e 5.0L or 5.7L or you can run the cylinder head or block casting numbers to see what you got sometimes there is a lot of gunk built up so their hard to read
87 trans am 350 L98 aluminum heads,LT4 hot cam,slp runners,headers,y-pipe,edelbrock base,hi flo cat,air foil,ported plenum,t-5 tranny w/centerforce clutch and a 3.27 9bolt,ads strip chip,relocated iat sensor,hollowed maf
14.10@97mph w/2.01 60' LOOKING TO TRADE?ANYONE
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
