another knock sensor question
Old Jun 22, 2001 | 11:19 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
what is the difference between a 89 knock sensor and a 91-92 knock sensor?i've read somewhere(don't remember where)that the 91-92's aren't as sensitive as the previouse years.can any one tell me if this is true or not?the last time i was at the auto parts store i asked the counter guy to check to see if their are two different part #'s and there were.
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://discussion-board.com/GreaterC...dyAssociation/
http://www.cincyspeed.com/
Old Jun 22, 2001 | 11:56 AM
leirch's Avatar
I had the same question. I just bought a 90-92 KS when i did the SD upgrade. I could have left the 87 KS in there, i actually put the MAF system back in while i was still in the rough stages of tuning and it ran just fine. But like you said, there has to be a difference, i don't know what it is though.
I have an 87 350 KS if anybody needs one for cheap.
Brendan
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Old Jun 22, 2001 | 12:04 PM
91banditt2's Avatar
Engine: 5.7 HSR
thanks!
so who here knows the difference between the two?
Old Jun 22, 2001 | 06:01 PM
e-man's Avatar
Car: 89 formula
Engine: 383
I would really like to know my self going to change mine real soon.
89 350 TPI,comp cam,edelbrock intake base,SLP headers,highflo cats,flomaster cat back,accel 300+ ign,ported plenum and runners,ported maf,auto w/shiftkit,cold air induction,AFPR,Ed wright chip,3.23 posie best ET 14.011@98.72mph without cam/New best 13.926@98.27mph
Old Jun 24, 2001 | 12:27 AM
91banditt2's Avatar
Engine: 5.7 HSR
anyone?
Old Jun 24, 2001 | 06:27 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Call a GM dealer and ask the parts guy to look both of them up. I didn't think there was a difference between the 2.
bamaboy0323
Sep 3, 2015 06:07 AM
db057
Aug 22, 2015 08:17 PM
redmaroz
Aug 16, 2015 11:40 PM
gwade12
Aug 8, 2015 08:17 AM
