Timing and intake backfire
Old Jan 11, 2008 | 06:44 PM
visionpb16's Avatar
I have a 1991 Z28. The mods I have are bored 30 over, ported heads, cam, 1.6 roller rockers, mini ram intake, a 58 mm throttle body, and a custom burned computer. I'm not sure what my timing is set at now, but for some reason i think its at 4* BTDC. Should I advance the timing more? Whats a good base to start at? Or what is the best way to find where to set the timing at? Also how much power can can you gain from timing? About the intake backfire, i have checked all of the vacuum lines and they are all fire. I just happens occasionally when i floor it. Any idea what might be causing this backfire?
Old Jan 12, 2008 | 06:53 PM
visionpb16's Avatar
Re: Timing and intake backfire
can some one help me out??
Old Jan 14, 2008 | 08:21 PM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
We just built and engine for my son's 91 RS. Won't go into all the engine stuff but it's a little different. Anyway we also had a backfire up through the throttle body with the timing set at stock settings (or near stock). We ended up advancing the timing a lot. It's out in front of the timing plate now by a half inch or so and it stopped backfiring. Ours is a TBI set up so it "breathes fire" when it popped. Oh yeah, we could have installed the cam gear up to 4 degrees advanced or retarded but choseto set it in the "stock" keyway.
Don't know if that will help you or not but it's something to try.
Old Jan 14, 2008 | 08:47 PM
camarorsssss's Avatar
Car: 1991 camaro rs convertible
Engine: Built ls1
Axle/Gears: 3:42
Hey Z's r Best, did ur pop go away and the backfire disappear? i am having the same issue, we went through everything to figure it out but it only occurs when you go full throttle quickly, it hesitates and pops through the throttle body and flames occasionally accompany the pop. we have the timing set at 0. everything else is dead on in the car, w e had it hooked up to a scanner to test everything else, but no answers.
Old Jan 23, 2008 | 09:49 PM
06andersen's Avatar
i to am having the same problem???? help??
Old Jan 23, 2008 | 10:55 PM
Elephantismo's Avatar
Car: 91 z-28
Engine: 350 F code
Transmission: 5spd
I cant be sure, but typically you are supposed to centerline your camshaft if you swap a new one in.
Even though a cam may be approximately centerlined by the dowel with stock timing gears and lineup marks, deviation from stock number one intake valve centerline angle needs to be adjusted with the cam sprocket to ensure desired operation and ease of tuning. Also centerlining the cam ensures your cam lobes are properly timed to piston position.
Other changes in the cam profile can also result in higher base timing being necessary. Some inexpensive dyno programs can estimate the general effect of different cam timings.
Without accounting for a large change in intake centerline and duration increase (a result of lift increase) you could end up with an intake valve slightly open while firing while the advance is properly set compared to piston position.
Can someone back me up here? Or explain in more detail?
This isnt neccesarily your whole problem, but it could be part of it.
Old Jan 24, 2008 | 03:00 PM
BOSS 357's Avatar
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
God I hate intake backfires. I had this happen after I installed my ASM runners. The short version of it is, the runners were warped -even after I had sent them back- and I continually overlooked it looking for something else to be the culprit. I had a massive vac leak on the runner and had to advance the timing to some crazy number just to keep the car running. Fixed the leak and the car just purrs.
Eric
Old Jan 24, 2008 | 06:15 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I think that you are too retarded. Start the engine up and get it up to proper operating temperature. Shut the engine off, remove the EST wire on the distributor. Start the engine up again and set the timing to 6 degrees or a bit higher. Do it right with a timing light. You have to do this with the EST wire disconnected. Otherwise the computer is going to undo every move you make.
Old Jan 24, 2008 | 08:11 PM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
TPI intakes will Pop when you hit the throttle if the fuel mixture is too lean. Commonly referred to as "Lean Pop".
Check your fuel pressure at the Fuel Rail with the vacuum line disconnected from the Fuel Pressure Regulator. It should be set somewhere between 44 to 50 psi.
Old Apr 22, 2010 | 07:19 AM
serpentracer's Avatar
I know this is a old thread but I want to hit on what mnorton said, this can be your problem.
I had to put a new pump in a 2002 blazer because it's pump was way too weak and back firing in the intake. the guy bought one from the internet that claims it will work but was labled for a different truck. ( trying to save a few $) so he ultimately ended up buying a proper pump.
the lesson here is don't jerry rig to save a buck. it often ends up costing you 2x as much in the end.
and yes, a weak fuel pump can cause them to back fire.
the blazer vortec needs at min 58 psi to even start. the pump he bought would only produce 45psi. once started it would run around 55 but didn't have the *** to pump up the psi when you give it some gas.
that's why everyone working on it was so stumped. they were going to give the truck away they were so fed up. over a $250 pump.
Old Apr 22, 2010 | 08:58 AM
I also wanted to add the pressure should jump almost instantly up to full psi when you turn the key on. not gradually climb. that's another tell tale sign the pump is weak.
1992 Trans Am
May 10, 2023 07:19 PM
midge54
Dec 27, 2019 04:14 PM
Andrew6.688
Dec 13, 2015 10:59 AM
db057
Aug 22, 2015 08:17 PM
