Air filter experiment
Old Jun 23, 2001 | 09:48 PM
PONTIMANIAC 90's Avatar
Car: 1990 Formula
Engine: treefitty
Transmission: stick
I have a cone-type K&N filter directly on my TB. Some folks say: "You're sucking up hot air.Go back to the old set-up but with a open element filter".
I did. I lost power! It was very noticable. Throttle reponse was shot to hell.
Maybe my Cowl hood cools things off a bit. But I noticed a slight power increase when I originally put the filter on my TB. I imagine a cold air kit might work a little, but a filter directly attached to the TB(hot or cold air)has to give you better flow than any air routed through corners and bends of a Cold Air Kit, and especially the stock air silencer.
I'd like to hear some opinions, based on experience.
PS I hope I posted to the right section.
1990 Formula
Factory:TPI-305/Dual Cat(230hp),5 Speed,3.42 rear, Dealer:Aluminum Drive Shaft
Mods:SLP air foil,K&N Filter, Accel:wires,coil cap,rotor.Hypertech Thermomaster chip,Stat,Fan switch,TES headers,MSD6AL,AFPR(46), Harwood fiberglass hood,original GM "Notchback GTA" hatch.
Flowmaster 3" Cat-back exhaust,TB coolant bypass, Centerforce dual friction clutch.
1999 Lexus GS 400 everyday car(It's a V8 so its not Rice)
1987 Voyager Minivan. Cost me $300=runs like new.No repairs for over 2 years(fingers crossed)
DIRECT LINK TO PICS OF MY CAR. NO WEB-PAGE. http://community-2.webtv.net/MZavraz...A90/page9.html
Old Jun 24, 2001 | 06:27 PM
CamaroZ_85's Avatar
well i was wondering if there would be enough clearance bewteen the hood/belts to do that, thanks for the answer!! thats what i plan on doing when i do my tpi swap cause i dont have the air cleaner setup
85 Z28- 350, Comp 262, Edelbrock Performer intake, Edelbrock 600 cfm carb and Edelbrock cat back, Summit headers and vette servo
-JVC, Eclipse, Pioneer, MTX, Phoenix Gold, Planet Audio
Old Jun 25, 2001 | 12:54 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
The only question to be asked is, how are you evaluating this? Maybe you 'felt' faster, but it could just be the extra noise/your imagination. Unless teh stock style filter is completely clogged i don't see how throttle response could be seriously affected. And WOT differneces are in the 5hp max range, no way in hell you feel that.
...ed
Old Jun 25, 2001 | 02:05 PM
Guest
Guest
Posts: n/a
SOTP.... not the best way to measure things.
I wont say I had the best test vehicle... but I took the air inlet off my TA and attached the MAF directly to the rubber bellows at the track about 1.5 years ago, and it ran slower. I dont have the slip here in front of me, so I wont be able to post until later about the actual difference. It definitely had crisper throttle response, and I would say that part-throttle was better, but WOT was not, and the timeslip showed that.
Old Jun 25, 2001 | 04:35 PM
RW91B4C's Avatar
I took my K&N cone and mounted it behind the left headlight while connecting it to the TB with some 4" aluminum heater duct, that way you get the filter moved away from all the engine heat (behind the radiator), and it should get a little cool air that comes around the headlights and all the little gaps. I thought the throttle response really picked up with this set-up, but I dont know if it really helped because that was one of the many mods I tryed when my car went from stock 15.0 to 14.1 I would like to make some kind off good high flowing ram-air set-up, but I think the factory ducts are just too small. I want it to work good on my 383. I measured the Holley 58mm TB - twin 58mm and the round hole at the front of the filter intake(plastic duct to the filters) was only 3 3/16" dia. just a little bigger then one 58mm holes - not good. So I'm still thinking of how to make a good high flowing cold/ram air set-up, maybe off the cowl hood? Any ideas???
91 B4C 305 TPI - SOON TO BE 383
TREMEC 5-SP, STOCK 1-BOLT REAREAND w/342 GEARS, K&N, AIRFOIL
EDELBROCK HEADERS, DUAL CAT TO HOMEMADE Y-PIPE & 3.5" SINGLE PIPE W/ FLOWMASTER, CRANK PULLEY, MSD, FUEL PRESS REG, COWL HOOD, WELD WHEELS
14.1@ 98MPH
OTHER RIDE
67 CAMARO - STREET CAR, BIG BLOCK, PUMP GAS
350TH w/ATI 10", 12-BOLT w/373 GEARS
10.94@124.13 ON MOTOR - ET-STREETs w/MUFFLERS
Old Jun 25, 2001 | 10:56 PM
Car: 1990 Formula
Engine: treefitty
Transmission: stick
<font face="Verdana, Arial" size="2">Originally posted by Ed Maher:
...ed
</font>
Yes way, Ed. I felt it go much, much slower when I put the old setup back on.So much so that I noticed. I wouldnt have mentioned it if I didn't.I **** you not.
The air filter I used was a K&N filter that came w/the car(like the stock one). I modifyed it so it was closed off at the bottom and attached it to the air silencer thing w/out using the air cleaner box. I just showed it on the hole. It was very notacible. I was surprized.
Old Jun 26, 2001 | 08:38 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
In my exerience, sometimes the amount of EXTRA air that you get from having an open element is more than compensated for the extra heat generated by the engine.
I Installed the Holley Projection on my old 67 Riv, and the Open element Air intake temp never exceeded 110° on a 80° day. I DO know that colder-more dense Air does help, but if you strangle your car of air then what difference does it make.
Do what you think works best.
John
87 Formula Yellow/Black
Engine & Transmission
.040 over 5.0 converted to TPI, 9.5:1 Compression, SLP Cam Dur 206/212, Lift 480/487, Cent Line 112, SLP headers, SLP cat-back exhaust, K&N Airfilter, Modified Stock cold air intake, Ported & polished Stock TPI intake, Holley Adjustable Fuel Press regulator, AC Rapidfire Spark Plugs.
Gil Younger (no yo-yo) Shift Kit, Aluminum Driveshaft, 3.73 Posi gear
Suspension & Brakes:
Baer 12" brakes 4 wheels, KYB AGX Adjustable Shocks & struts, Hotchkis strut tower brace, South side machine frame connectors, Custom reinforced control arms and pan hard bar.
Interior:
Custom Leather interior, CUSTOM Yellow Gauge Faces, Kenwood Receiver, Pioneer Speakers, Kicker Substations, Kenwood 10 Disk Changer, Pioneer Amp.
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro (Parts)
83 T/A (parts)
http://www.3rdgenformula.com
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Brinkkl2000
Aug 4, 2018 08:29 AM
Thornburg
Sep 1, 2015 03:39 AM
