ZZ4 Cam - Yes, Again... Q about Lifters
Old Jun 26, 2001 | 10:10 AM
Jim 86 Bird's Avatar
Car: '89 TA
Engine: LB9
Transmission: M5
Now that I've got this cam, I'm gonna need to round up the parts that need to go in with it:
TPIS springs, New valve seals (while i'm at it), and now I keep getting told I need MATCHING lifters for the cam...
...alright to be honest, i kinda know what they are, i kinda know what they do, but i have no clue as to how i pick out a set that "matches" this zz4 cam, so if anyone can help that'd be awesome
I'm a while away from doing this but I'd better start learnin' now if I wanna do this right
http://www.tcnj.edu/~esposit3
https://www.thirdgen.org/rides/index...ew&rideid=1137
  • '89 Trans AM, 305 TPI, 5-spd
  • '86 Firebird, 2.8, Auto
AOL IM Name: JimmyTime5
Old Jun 26, 2001 | 11:16 AM
ImportsRsloths's Avatar
I have an 88 Iroc 305 TPI 5 speed.... i dont have any answers to your questions, but i really want to know how that ZZ4 affects your performance when you put it in.
Old Jun 26, 2001 | 12:08 PM
blak92!'s Avatar
Since you have a roller motor, you can reuse your lifters (since the lifters have a little roller with roller bearings that "roll" on the lobes of the cam and produce virtually no friction).
Inspect the lifters thuroughly and make sure there is no visible damage.
Hybrid Black 5.7L 5 Speed
'95 Competition Yellow Corvette Coupe ZF6
Old Jun 26, 2001 | 12:33 PM
Car: '89 TA
Engine: LB9
Transmission: M5
Thanks Black92. Can anyone second his opinion about re-using my existing lifters? (I just wanna be sure, man)
ImportsRSloths, don't worry, when I DO eventually put the cam in it'll get a battery of tests and reviews... butt-dyno, englishtown slips, and every member of FBS will get to romp on it , then i'll post the results here.
Member of FBS, The F-Bod Squad, 3 guys so far and I don't think we're growing
Old Jun 26, 2001 | 02:30 PM
b92z28's Avatar
reuse your old lifters only if they are in good shape.
92 z28 170,000 miles 14.20 on goodyear eagles before exhaust only mods k&n and slp 13/4 headers and dual 2 1/2 exhaust
87 trans am 12.20 on motor too many mods to list
Old Jun 26, 2001 | 05:23 PM
Car: '89 TA
Engine: LB9
Transmission: M5
Ok, sounds good, assuming I'd need lifters, how should I go about finding something to match the ZZ4 Cam?
[This message has been edited by Jim 86 Bird (edited June 26, 2001).]
Old Jun 26, 2001 | 05:55 PM
sparks383iroc's Avatar
Car: Mullitt mobile :)
Engine: it's stock LOL
Transmission: 700rJunk
Axle/Gears: 2 much 4 street not enough for strip
'89 L98 Iroc, 130K miles before rebuild and I reused my roller lifters with the ZZ4 cam.
You shouldn't have any problem re-using yours, but if you want to get new ones Comp Cams make some: Part #850-16. You can get them from Jegs or Summit.
Sparks a flyin'
Jorlain
Oct 8, 2015 01:57 AM
J.C. Denton
Sep 8, 2015 05:35 PM
Stryker412
Sep 7, 2015 09:11 AM
dimented24x7
Sep 6, 2015 03:51 PM
z28guy134
Sep 1, 2015 11:50 PM
