motor block question
Old Jan 13, 2008 | 04:03 PM
tpicamarokid85's Avatar
Car: 1985 Z28 (project) drive 2006 F-150
Engine: to be deturmined
Transmission: to be powerglide
Axle/Gears: to be 9".. spool.. possibly 5.14:1
when i first bought my 85 z28 at 15yrs old, the guy told me it was an l88 out of a corvette. now that i have bought it back and am starting an overhaul on it, i did research on the 350 tpi. since that is the intake on it i figured the guy had his numbers mixed up and meant l98. now i am starting to have second thoughts on my research and am trying to find casting numbers for the block on the L98 and L88 to figure out just which block i have. the research i have done says the l88 is a 427 and my question is will the 350 tpi intake bolt up to a 427 block? and does anyone know where i can go to find a casting number breakdown?
Old Jan 13, 2008 | 04:30 PM
rosco88ta's Avatar
Car: 88 Trans Am
Engine: 355 c.i.
Transmission: 5 spd.
Axle/Gears: 3:42s
Re: motor block question
It would be my guess the guy got the numbers wrong. A L88 is a 427 big block from the 60s A L98 is a 350. A small block intake will not bolt to a big block like the 427 454 0r 396
Old Jan 13, 2008 | 04:32 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
the answer to the sbc intake bolting up to a bb 427 is a definite no. As for the l88 i know nothing about those castings but, the l98 is a sbc 350 tpi factory f-body engine which is much more likely id expect.
Old Jan 13, 2008 | 04:35 PM
thanks... that answers one question...and i didnt think my luck was good enough to come across an l88. the other question didnt get answered though,.... does anyone know where i can get my casting numbers broke down to make sur eits the L98 block...
rosco88ta's Avatar
Car: 88 Trans Am
Engine: 355 c.i.
Axle/Gears: 3:42s
Try Mor Tec, Inc. for your casting numbers
MustangBeater20
Oct 29, 2022 09:20 PM
jhawkeye
May 25, 2022 06:33 PM
theshackle
Mar 5, 2017 06:37 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
