86 upper TPI unit, and 87'newer wiring harness???
Old Jun 27, 2001 | 08:01 PM
STUB25's Avatar
I have a 86' lower mani. and 87 upper I am wondering if there is a diffrence between the wiring harness. I know there is in the TPI unit and the ecm but what about the wiring?? HELP ME!!!
Old Jun 27, 2001 | 08:47 PM
Vader's Avatar
Stub,
No, there should be no real differences. Both years used the cold start injector and all the same sensors. The only significant difference is that the '87 had a separate ignition coil and the '86 had the integral coil (in the distributor cap).
EGR solenoid, IAC, TPS, injector harness, CTS, MAT, temp. gauge sender, alternator field, etc, should all be plug-compatible.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Jun 27, 2001 | 08:49 PM
Vader's Avatar
P.S. - See you on the beltline....
Later,
Vader
Old Jun 29, 2001 | 08:01 PM
STUB25's Avatar
Thanks vader, you from the Madison, WI area?? If not whats up with the beltline??
Vintageracer
Jan 10, 2020 05:33 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Reddeath210
Oct 6, 2015 08:20 AM
Sanjay
Aug 12, 2015 03:41 PM
