When I come to a stop idle stays high
Old Jun 27, 2001 | 07:03 PM
AFRO IROC Z's Avatar
When i come to a stop my car idles at 1500 rpm , but if i tap the gas real fast the idle will drop to 750 like normal. Anyone have any ideas as to why my car does this. If i don't tap the gas it will continue to idle like this. Thanks.
Old Jun 28, 2001 | 02:41 PM
89IROCkid's Avatar
I have the exact same problem. It's the throttle blades/shafts binding somewhere in
the throttle body. I'd check the throttle, cruise cable and free mouvement of the thottle body. Even i've checked all these, removed my throttle body several times, it still does the same thing. I was told by someone on this board that the only way out might be to change the throttle body.
Sat "IROCkid" Bimrah
1989 IROC-Z 5.0 L / 5 spd
Old Jun 28, 2001 | 10:47 PM
Ozzy88GTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.0 TPI
Transmission: TH700-R4
This all sounds like a mechanical problem and not an electronic one, or even a vacuum leak. By tapping the gas you are giving the throttle more momentum to return to fully closed position, this could indicate binding like he said or even a weak return spring on the throttle body.
Don't forget to also check the TPS, the linkage arm could be binding.
Old Jun 29, 2001 | 08:18 PM
irocnroll89's Avatar
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
well, i have checked about everything, and it doesn't seem to be mechanical. I am wondering if it in the prom, cuz i notice it now that i have changed trannies........
'89 SHAGGY IROC
L98, W/C T5, all free stuff,T.E.S.,HOOKER CAT BACK,KYB,ACCEL8.8,JET fan sw. etc. 14.8@ 95.7MPH w/ auto, can't wait for the first T5 run.
so much to do , so little money
[This message has been edited by irocnroll89 (edited June 29, 2001).]
apo_bailon15
Mar 28, 2016 05:20 AM
db057
Sep 4, 2015 07:57 AM
EFR2000
Aug 18, 2015 08:54 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
