Intake Manifold
Old Jun 28, 2001 | 11:24 AM
IROC-Z_85's Avatar
Intake Manifold
Well in another post I just mentioned that I'm installing a new cam. Thus everything is torn apart. So what I'm wondering is what is the most restrictive places in the intake manifold to port, is it anything like the plenum with two obvious spots that need improvement, or is the general idea to widen the whoooooole port. I dont mind touching it up with a grinder while its off, but I want my car back on the road by saturday and I only have weekends to work on it. If anybody has any good manifold porting info please help me out, thanks.
1985 IROC-Z, nuff said :P
Old Jun 28, 2001 | 03:43 PM
IROC-Z_85's Avatar
Also:
160 or 180 thermostat?
Im thinking 180
Old Jun 30, 2001 | 09:04 AM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
If you live in:
The Artic Circle - 195°
Cooler Climate - 180°
Warmer Climate - 170°
Hotter than Hell - 160°
Old Jun 30, 2001 | 11:36 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
You want to open up your lower intake as large as possible. You can hand port it, but it will take a lot of time. Extrude hone takes 3 weeks. I don't think the stock runners are thick enough for a lot of material to be removed. Get some large tube runners to help out with flow. The lower intake manifold is the most restrictive part of the tpi system. Try and open it up to 1.75 inches if you can, but then your runners will hold you back.
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Blue419
Sep 10, 2015 01:03 PM
BOOT77
Sep 5, 2015 03:55 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
