89 tpi won't start when cold
Car: 91 Z28
Engine: 6.0 LSX 88 Turbo, EFI E85
Transmission: Glide
Axle/Gears: Strange 3:73 9"
I have a 89 iroc, low milage car 350 TPI that since I bought it, does not want to start when cold, you have to keep trying and trying, once you get it going seems to run fine and will restart with no problem. I know this does not have the 9th injector, could the coolant temp sensor cause this ? thanks for any help, Rob
Car: 89 formula 350
Re: 89 tpi won't start when cold
I just had same problem with low milage '89 formula 350. Try advancing the timing, I set mine at 10* btdc and it really helped and runs great. Just mark the dist. first then turn it counterclockwise some, see if it helps, if not, put it back.
Sanjay
Aug 12, 2015 03:41 PM
