Hard to start
Old Jul 2, 2001 | 01:16 PM
lindseymillar68's Avatar
Hard to start
My car is a 88 Trans-Am 305 Auto TPI. Starts fine when cold (1st crank), but when warm, it seems to turn over forever before it catches. Thanks in advance for any help you can provide!
Old Jul 2, 2001 | 01:36 PM
IROC-Z_85's Avatar
I ran into a recent hard start problem and it was my timing.
Thats an easy free one to check
1985 IROC-Z, nuff said :P
Old Jul 2, 2001 | 02:36 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Off the top of my head
-a bad CTS could be telling your ECM the wrong temp when warm, thus using a very non-ideal start-up enrichment/spark advance
-Your cold start injector switch that activates it is bad and is causing it to come on when it shouldn't (ex. on a warm start.) You should be able to check this easily by disconnecting the CS injector.
Most other long crank problem i can think of offhand would be as bad/worse when cold. Your problem seems to lie in the engine management system. Then again, it could be something dumb like your starter is cranking reasonably slower when heat soaked, and thus makes it that much harder to fire up.
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Old Jul 2, 2001 | 04:32 PM
yellowiroc2's Avatar
Car: Z06, WS6
Engine: LS6, LT1
Transmission: M6
Where is the cold start injector and what's "cts"? I have this very same problem on an 86 305 iroc. Starts easy when cold, cranks forever when warm.
Old Jul 2, 2001 | 04:45 PM
IROC-Z_85's Avatar
CTS - Coolant Temperature Sensor
And the 9th injector is at the base of the driverside runners in the middle
Old Jul 2, 2001 | 06:39 PM
Well, I pulled the connector off the cold start injector (when the car was warm), and then it was REALLY hard to start. Put the connector back on, and it started on the first crank. When it starts, though, it tends to 'stumble' to a start with a moment of silence and then a high idle @ 1200-1500 RPM. How do I test the CTS? thanks for all the replies.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
cstrobel65
Aug 15, 2015 10:19 AM
92camaroJoe
Aug 13, 2015 06:07 AM
