confused about injector size!
Old Jan 18, 2008 | 12:49 PM
Mirocz87's Avatar
Car: 1988 Formula
Transmission: t-5
hey guys i am getting really confused over what sized inectors i should be using... iv got a 350 with 202 heads, flat top pistons, hooker high flow headers, an rv cam, and the stock 305 tpi intake.. i need to swap the old 19 ers out with bigger ones.. iv been looking around and the whole duty cycle issue is confusing the carap out fo me.. all the injectors iv been looking at are rated at 100% duty cycle.... so i guess what im asking is would 24LB injectors rated at 100% duty cycle be enough or too much for my setup? thnx!
Old Jan 18, 2008 | 02:43 PM
psy4s's Avatar
Re: confused about injector size!
Yes they should be fine.
Old Jan 19, 2008 | 12:10 AM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
24 is ok, depending on ur hp output ur gona have to adjust the pressure. stock 350tpi run 21lb. and are good for 300hp if u dump the pressure to 50psi.
Old Jan 20, 2008 | 11:04 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I recommend the 24#/hr Ford racing fuel injectors, and buy a good AFPR, and a good fuel pressure gauge. An AFPR is a very valuable tool when it comes to tuning, and to use it properly, you must have the fuel pressure gauge.
Measure the fuel pressure now, and then set the AFPR at that pressure after installing the 24#/hr injectors. Adjust from this starting point to maximize your performance which could be done at your local dragstrip.
I am assuming you have a MAF car being an '87 like mine. You probably have enough adjustability in the ECM to account for the 24 #/hr injectors. However, if you dont, you will need to get an Eprom chip burrned for the 24s.
Old Jan 20, 2008 | 03:39 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
The stock 19 LB injectors will probably work fine with your combination and then you would not need a new chip. The 19 lB injectors will work fine to about 325 flywheel HP.
Old Jan 20, 2008 | 06:58 PM
Car: 87 TA clone
19lb injectors can run on a 350 but u will be maxing them out bc u will be bumping the pressure to 50psi or they will create a lean condition... not good for the motor, on a 305 the 19lb injectors are good for 300hp id say maybe... but on a 350 u might get away with 260hp. i would def go with 24lb SVO ford injectors.... they are good quality. i got the ford SVO 30lb for my 500hp HSR 383
and def get an adjustable regulator and fuel gauge as doc said. u will need to adjust it for tuning purposes
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
knight72
Aug 10, 2015 09:32 PM
