battery ground wire .. ??? where does it go
Old Jan 19, 2008 | 06:03 PM
Adrians91Z28's Avatar
Car: 91 Camaro Z28 Convt.
Engine: 305 TPI (built)
Transmission: 5 spd
Axle/Gears: 3.08 posi
i just got my 305 tpi back in my 1991 camaro convertible ..
almost ready to start it after a complete (re) build .. but i cant figure out where the ground wire (negative / black) bolts to ... the big end of the wire that comes off the battery ..
does it bolt to the block .. if so where .. ???
ive looked for a while and only thing i can see is the back of the a/c and smog pump bracket ..
also theres a hole in the block left of the oil pressere sensor .. just above a freeze plug .. do i need to plug this hole .. does coolant or oil pass by it? ..
thanks ..
adrian
Old Jan 19, 2008 | 10:09 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: battery ground wire .. ??? where does it go
bolts to the bracket on front of engine under smog pump. basicly anywhere on engine it can get a ground,later jimmy
Old Jan 20, 2008 | 08:34 AM
Transmission: 5 spd
yea .. i think i remeber seing a short bolt that i left in the old heads .. im sure thats it .. and i think that bolt goes in the whole i found that is under the smog pump like you said ..
thanks for clearing it up ..
adrian
Glowsock
Jul 24, 2025 03:15 PM
eightsixseven
Dec 16, 2024 01:50 PM
Street Lethal
Apr 30, 2019 12:14 PM
Jae992
Aug 27, 2015 09:07 AM
