How do you set fuel preassure?
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
I have an adjustable regulator. Whats the procedure for setting the regulator? thanks
1987 T/A GTA 5.7L, Bored .020 and ported for .202 valves, edelbrock headers, flowmaster exhaust, JET STAGE II chip, Comp CAM, Adjustable fuel pressure, Airfoil, K&N filter, B&M stage 2 shift kit, and a home depot ram air(Hey it looks good and it works)
Car: 92Z, 96RamAir, 91 4X4 Burb
Engine: 383 Super Ram, LT1, 350 roller
Transmission: 700R4, Probulit 700R4 &4L60E, 4L80E
Remove vacuum line and plug line. Leave AFPR port uncapped. Attach pressure guage/hose to the shraeder valve on fuel rail.
Start engine. Read gauge. Adjust AFPR srew clockwise to increase pressure, counter-clockwise to reduce pressure. Try small adjustments in steps (~2-3psi at a time to see where performance/idle change).
Remove all components and replace vacuum line to AFPR.
KevinP92Z
92 Z28 383 SLP cam,SLP headers,SLP 2ontheLeft,Trick Flow TW heads & pistons,Edelbrock base,Accel SuperRam,52mmTB,Scat Crank & forged ConnRods,MSD 6AL,SLP convertor,Baer 13/12" Track,Moser axles,Hotchkis,Genuine GM 3.42s,SLP HD Torsen,17x9" chrome SS rims
96T/A w/SLP Ram Air,SLP 2ontheLeft, Bilsteins, Baer, Hotchkis, Genuine GM, Torsen
76 4X4 Blazer 400TPI project
KevinP92Z
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Thanks for the info but based on my mods do you have an idea of what a base setting might be. Im way high on it tight now i think
Car: 1987 Z28 Convertible
Transmission: 5-speed
Kevin did an excellent job outlining how to physically adjust fuel pressure. To determine where to set it, you need a scanner to monitor O2 sensor readings at WOT. This is the only scientific way to adjust pressure. It should read 800 - 850 mV. If too high, lower pressure. If too low, raise it.
Willie
Supercharged 1987 305 IROC-Z, Daily-Driver, Emissions-Legal.
Former Paxton (6-psig): 12.57 @ 111 mph.
Former Paxton (6-psig) & former 50-hp nitrous: 12.04 @ 114 mph.
ATI D1SC (8-psig): 12.06 @ 115.94 mph.
Future ATI D1SC (?-psig): Gotta catch them pesky 26-psig boosted TTA's!!
http://willie.camaro-firebird.org/
1987 "20th Anniversary Commemorative Edition" Z28 Convertible -- Super Chevy Show Class Winner, 1998.
[This message has been edited by Willie (edited July 06, 2001).]
Willie
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
To do this do you make an adjustment first. Then crack it ope full threottle for a few seconds to get a reading?
Firechicken86
Aug 12, 2015 10:07 PM
