oil for racing, 30 or 50
Hey guys, im thinking about going down to the drag strip this friday, and
i'll be making at least 5 runs probably. Now I am currently running 10W-30
Mobile1 Synthetic. Im thinking about putting some Valvoline 50W racing
oil, my car has 206000 miles on it (maybe a rebuild at around 100,000 not
sure). Now is it true that running the 50 weight will protect my engine
better (bearings etc.) by being thicker? Just for the same reason you use
70-90 in the rear? Well i hope someone here nows wut im talkign about and
can help!!!
88' GTA 350 MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass
can help!!!
Car: 1984 Z28
Engine: 454
Transmission: Th400
I dont think 50w valvoline will protect your engine as good as mobil 1. Mobil 1 or any good synthetic can withstand more heat, also 50w oil would cause your oil pump to work harder and you would lose some power.
<font face="Verdana, Arial" size="2">Originally posted by giovanhalen:
I dont think 50w valvoline will protect your engine as good as mobil 1. Mobil 1 or any good synthetic can withstand more heat, also 50w oil would cause your oil pump to work harder and you would lose some power.</font>
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
