1991 Pontiac tpi 350
Old Jan 26, 2008 | 05:25 PM
jmonkey91's Avatar
Hello i bought this car a year ago not running got running and found that after i run the cra for a while and press on the accelerator very little it starts to smoke black and run super rough like it is runnig rich i thought it is a IAC motor just wondered if anyone else had simalar troubles any advice thanks
Old Jan 26, 2008 | 09:38 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: 1991 Pontiac tpi 350
Sounds more like a sticking egr valve, or, solenoid.
Old Jan 26, 2008 | 10:10 PM
DSmith's Avatar
Car: 1989 Camaro
Engine: 383
Check for vacume leaks, could be the MAP sensor thinks your flooring it.
Also check out your TPS, I have never messed with a sd car but I guess its possible that if the ecm is seeing a high voltage from the TPS it could also thing your on the gas and start dumping fuel.
Again, I have never messed with a SD TPI so I could be wrong.
jhawkeye
May 25, 2022 06:33 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Cripley
Aug 17, 2015 03:35 PM
Jlanz55
Aug 17, 2015 07:15 AM
Sanjay
Aug 12, 2015 03:41 PM
