Siamesed Intake Questions w/in
Old Jul 10, 2001 | 11:45 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
Next week i was planning on siameseing the intake. I was wondering how far i should take it into the base if i wish to pull upto 6000. Is this a good idea for me? Lowend isn't much of a concern because my torque converter just flashes upto 1500 as it is so i doubt the loss of low end torque with siameseing would make a different... I just want to be able to pull to where my tranny shifts (and no it doesn't exactly shift at 6000 but maybe around 5500 or somewhere close). Any help is appreciated.
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Gutted cat
-!AIR
-Gutted Air Boxes
Old Jul 11, 2001 | 01:20 AM
Ski89Z28's Avatar
Here is the thread Madmax started about the siamesing of the intake.
https://www.thirdgen.org/messgboard/...ML/001492.html
What I remember about it is that Madmax siamesed about 5 - 5.5 inches from the runner side to the heads, on a stock manifold. Madmax did dynos but had problems so it was kinda inconclusive but his g-tech runs with a regular intake and a siamese intake showed a .4 to .5 second decrease in times.
But the other guy, Mike, did siamesing on a edelbrock manifold and only did 2.5". Mike found no real gains on his.
Mike did some great scientific data but since he only siamese 2.5" down it remains to be seen if siamesing 5 to 5.5" would yeild any better results.
I think also Mike said that the siamesing of a STOCK intake would yeild better results than a aftermarket intake but all of Mike's test where done on a edelbrock intake.
Read the thread cause I my have not remembered some of the stuff correctly as I stated above, sorry if I did.
Hope it helps!
89 IROC 350 Auto
Custom DUAL Exhaust
Edelbrock Performer 6085 Aluminum Heads
ZZ9 Cam
TPIS Level 5 Chip
And Free mods.
13.879 @ 98.90 mph (with 2.77 gears!)
Moderator of http://www.iroczone.com
Member of JFA Crew
Old Jul 11, 2001 | 11:08 AM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Will do, thanks for pointing that out.
89 IROC-Z 350 TPI
-Flowmaster Catback
-K&N Airfilters
-Ported Plenum
-Gutted cat
-!AIR
-Gutted Air Boxes
Frozer!!!
Jan 19, 2024 04:55 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
